RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Ryobi 31cc ? (https://www.rcuniverse.com/forum/gas-engines-142/9967664-ryobi-31cc.html)
Dave172 08-29-2010 05:32 PM
Ryobi 31cc ?
I have a Ryobi 31cc engine mounted on my GP Giant Stik. When I advance the throttle forward the engine will hesitate and then throttle up but only at about 50% power with throttle full open. I have a pitts style muffler mounted on the engine, when muffler is left off I have no problem with the throttle going to full power. No hesitation and l00% full power with no muffler.
Can anyone out there help me solve this problem?
STUKA BARRY 08-29-2010 06:05 PM
RE: Ryobi 31cc ?
ORIGINAL: Dave172
Adjust the low end needle. They should be marked H and L.
novayusa 08-29-2010 07:12 PM
RE: Ryobi 31cc ?
What pitts muffler do you have? In the description sounds like the muffler's problem.
Dave172 08-30-2010 12:04 PM
RE: Ryobi 31cc ?
It is a Bennett muffler
w8ye 08-30-2010 12:55 PM
RE: Ryobi 31cc ?
Some of the Ryobi's have a REV limiter in the ignition and it is set close to 7000 rpm so it is best to run a 18 -8 prop on them
I have a couple of these and one has the REV limiter. The ignition gets rough above 7000
Dave172 09-01-2010 05:46 PM
RE: Ryobi 31cc ?
I took off the engine back plate, made a new gasket and bolted the engine back to my mount. Took the plastic limiter caps off the need valves, adjusted the low end needle valve. It now runs great.
