Servo choices
I just ordered a Racer II kit and will order a SS Jett 40 in a week or so. This is the setup recommended for "standard" class racing here in Indiana and surrounding area. I will be using Futaba radio and want to know what servos would be appropriate. I don't want to buy digitals if they are overkill but don't want to underbuy and have poor performance because of the servos.
Thanks,,,basmntdweller |
Servo choices
The futaba that most of the racers are using is the 3002.
However at about $65 these get a bit spendy. Many racers are using Hitec 225s Nylon Geared servos in Q500 planes at nearly a 1/3rd the price of the 3002. They are also quite a bit lighter. I use Futaba Radios with Hitec servos, and do not feel like I am buying a sub-standard servo by any means. I am betting a large part of the Non-Sponsored racers are also using hitec 225s. They are battle tested. |
Servos
Matt, just what Daven says,,, HS 225's and you may want to consider the HS 81 for the throttle too :D
BV |
Servo choices
Definately use a smaller servo on throttle. Bill likes the 81, I prefer the 85.
Basically the same servo, I just think the gears a little stronger on the 85. |
Servo choices
Yup me too, love my bag of little Hitec's. I also prefer the plastic gear 225's for all but the throttle. Crash stripped gears are very cheap to replace and I can do those in my sleep now. :D However with the eighty series on the throttle I,ve never successfully replaced those gears so I tend also to use HS-85 there.
John |
Servo choices
Hey Guys,
Where can I find HS-85 Servo? I've looked everywhere for them and could not find one. I've been using the HS-81 and it work great, but I want to try HS-85 as well. Sam |
Servos
Servo choices
Thanks, Bill!
Sam |
HS 85
Originally posted by SSAN Hey Guys, Where can I find HS-85 Servo? I've looked everywhere for them and could not find one. I've been using the HS-81 and it work great, but I want to try HS-85 as well. Sam BV |
Servo choices
Servo choices
That's even better since I can purchase them there.
Thanks, Dave! Sam |
225's
Dn, them 225's always been rated for 67 inch oz's?
BV |
Servo choices
I had thought about the 225's. I've been using them on some of my funfly planes. Very fast and strong on 5 cell packs. I am not real impressed with their centering but with the small control surfaces of a quickie, it shouldn't be a problem. Thanks for the reinforcement.
basmntdweller |
Hitec Servos
Ditto on all of the positive Hitec comments.
I use Hitec servos exclusively on my Quickies and Q40's. I have standardized on the following config: HS-225BB Quickie (Webra Q engine) ailerons Q40 elevator and ailerons HS-85BB Quickie (Webra Q engine) one on each V-tail elevator and shut off Q40 rudder and shut off The HS-85 has a ball bearing where the HS-81 does not. With this strategy, I only have to stock two types of servos for all my racers. Can easily swap servos in and out as needed. All with nylon gears. Excellent service, fast and cheap ($0.00) ;) Another good source is Servo City Very good prices and free shipping in many cases. Randy Smith |
Re: 225's
Originally posted by Bill Vargas Dn, them 225's always been rated for 67 inch oz's? BV I once tried HS-85's at 42/49 on everything but that turned out to be a bad idea due to the two screw mount arrangement causing excessive servo rocking, particularly on ailerons. John |
| All times are GMT -8. The time now is 03:29 PM. |
