Predator help
OK I purchased the predator 2 and a thunder tigar pro .46 and the tower muffler..
any building tips or speed expectations? thanks, Dewayne |
RE: Predator help
I would glue some balsa with the grain vertically to the fuselage sides inside the plywood doubler inside the tank compartment before you fit the top cover.
RE: Predator help
1 Attachment(s)
Yes, triangle stock and epoxy all around the backside of the firewall and landing gear area inside the fuse.
RE: Predator help
Looks solid, I just glue the lid on and go through the rear
RE: Predator help
About 120 mph with the right prop and that motor should be doable.
| All times are GMT -8. The time now is 12:09 PM. |
