Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 05-05-2013, 10:42 AM
  #1501
hannes83
hannes83's Avatar
Default RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K
From CARF to scratch :-)
Old 05-05-2013, 11:50 AM
  #1502
Maxclimb
My Feedback: (61)
Hannes,
Is there any chance that you will offer the corrected cowls for sale? Even if you do not sand and paint them I would like to buy one.
Mike
Old 05-06-2013, 12:48 AM
  #1503
RichardGee
My Feedback: (156)
RichardGee's Avatar
Wow! Very nice
Your Gee Bee will be the fairest in the land...
Old 05-11-2013, 09:12 AM
  #1504
n8622t
My Feedback: (8)
That looks like a Hannes pilot😄
Old 05-11-2013, 09:15 AM
  #1505
n8622t
My Feedback: (8)
If anyone is online with the incidence numbers for the wing dihedral correct me if I'm wrong before I drill theses cable anchors in the next 20 minutes ... 5.5 degrees ???
Thanks for the help from anyone 😄
Old 05-11-2013, 09:42 AM
  #1506
n8622t
My Feedback: (8)
ORIGINAL: RichardGee
Bumblebee... WELCOME to the fascinating world of piloting a scale Gee Bee R2
It is difficult to give you exact advice designed to cure your issue.... FIRST, are you positive that the following are PERFECT??
Dihedral - minimum 4.5 degrees each wing and EQUAL
CG - 17-18% of chord? This equates to 73mm - 75mm back from the leading edge
Minimal rudder throws - the rudder is VERY effective on this plane
PERFECT rudder linkage with NO SLOP
Digital servos w/minimum 150 in. oz. torque
Aircraft is trimmed for hands off, level and straight flight at 3/4 throttle
Flying wires are ''guitar string'' tight?
Your engine, prop and weight are perfect, but the extra HP will indeed add some P-factor. Compared to a DA150 the affects will be minimal.
Once ALL of the above are confirmed, you MUST mix some right rudder with your throttle. The total amount of rudder throw from neutral is about 2mm. The rudder should NOT begin mixing until you reach approx. 50% POWER... at that point, the rudder should mix in a linear fashion until at full power you have 2mm right rudder deflection.
Assuming you get all of this correct, you will likely find that flying this airplane IS a continuous compromise. As Delmar Benjamin confirmed, it is UNSTABLE in PITCH and in YAW. Correcting this required an expert pilot sitting IN the cockpit sensing every deviation... we on the ground do not have the ability to sense subtle changes.
A GYRO would be a great addition, but simply adding a gyro will not fix the issues unless you have the gyro perfectly tuned to offset the Gee Bee's tendencies... this will take trial and error... and the by the time you have it dialed in, you will be an EXPERT Gee Bee pilot and may no longer need a gyro
Ok while I was waiting for a possible reply I looked back through the pages to find the info and as usual Richard is the man😄. Thanks for posting this Richard now on to the drilling
Old 05-11-2013, 09:43 AM
  #1507
n8622t
My Feedback: (8)
BTY , I can't believe a year has passed since I worked on this beast.... I'm feeling the shame guys
Old 05-11-2013, 12:22 PM
  #1508
RichardGee
My Feedback: (156)
RichardGee's Avatar
Visit my buddy Hannes in Germany :-)
Old 05-11-2013, 04:42 PM
  #1509
n8622t
My Feedback: (8)
Looks like fun to me
Old 05-11-2013, 11:45 PM
  #1510
hannes83
hannes83's Avatar
We had a great time!!
Old 05-12-2013, 06:54 AM
  #1511
n8622t
My Feedback: (8)
I got the holes drilled yesterday for the wires to attach inside the fuse...here is a question for you GeeBee veterans, with the wires stretched so tightly, what is the best or easiest procedure for assembling the wings at the field? I have had planes in the past with functional flying wires and they always required a certain procedure for assembly or it would be a frustrating event every time the plane went to the field. Richard and Hannes, you two come to mind on knowing the easiest method so if you guys could share your technique I would really like to hear it.
Thanks Fellas
Jimmy
Old 05-12-2013, 06:58 AM
  #1512
n8622t
My Feedback: (8)
cant post pics since rcu is on a snafu....[:@]
Old 05-13-2013, 07:52 AM
  #1513
n8622t
My Feedback: (8)
Ok I got it.... Loosen bottom bolts first , tighten last😄
Old 05-13-2013, 12:01 PM
  #1514
n8622t
My Feedback: (8)
I'm at 4 3/4 degrees dihedral incidence and guitar string tight
Old 05-13-2013, 12:03 PM
  #1515
n8622t
My Feedback: (8)
Too bad CARF didn't include some steel strap to add across the bolts at the bottom
Old 05-14-2013, 01:23 PM
  #1516
n8622t
My Feedback: (8)
Ok all the wing wires are installed and tuned to a G chord
ID:	1881970   Click image for larger version
ID:	1881971   Click image for larger version
Old 05-14-2013, 01:26 PM
  #1517
n8622t
My Feedback: (8)
I put the wing dihedral incidence at 4 3/4 degrees equally
ID:	1881973   Click image for larger version
ID:	1881974   Click image for larger version
Old 05-14-2013, 01:41 PM
  #1518
n8622t
My Feedback: (8)
Hannes I have been looking closely at your wheel pants and plan on adopting your mounting method...cutting the aft part of the wheel fairing lose looks like a great idea but how did you mount the fairings to the struts? I recognize the main screws that attach to the struts but the additional attachments are what I would really like to see...it you wouldn't mind sharing that information I would be very grateful for it...thanks
Jimmy
Old 05-15-2013, 06:19 PM
  #1519
n8622t
My Feedback: (8)
Got the throttle and choke set and engine dome near completion with only to cut ignition plug exits and fuel proof the engine mount
Old 05-15-2013, 06:22 PM
  #1520
n8622t
My Feedback: (8)
Hannes, what I thought were mounting screws on your wheel pants are actually the axles exiting through the side of the pants
another day of GeeBee construction and looking forward to tomorrow
Old 05-17-2013, 04:59 AM
  #1521
n8622t
My Feedback: (8)
Rudder tray and fuel tank tray are both in
ID:	1882580   Click image for larger version
Old 05-22-2013, 07:44 AM
  #1522
hannes83
hannes83's Avatar
Last test run before the maiden - CLEAR!!!
http://www.youtube.com/watch?v=5BYTkIDzQr0
Old 05-23-2013, 06:01 PM
  #1523
lumpy649
My Feedback: (75)
Beautiful aircraft Hannes, the engine sounds great. Enjoy the maiden and I'm sure we're all looking forward to the video.
lumpy649
Old 05-23-2013, 11:03 PM
  #1524
brezel53
Hello Hannes,
good luck!
Your maiden is my personal model aircraft highlight 2013!
Will press my 2 thumbs!
And yes, don´t forget your cameraman.
Wolfgang
Old 05-24-2013, 12:39 PM
  #1525
hannes83
hannes83's Avatar
The new custom wing bags are done, hope you like it!
