elevator Q 3d flying
MA
i am wondering how most elevators are set up for 3d flying are you guys using a equalizer such as a [link=http://www.smart-fly.com/Products/EqualizerII/equalizer.htm]smartfly[/link] or just using conventional set up and mixing the two servos together ? I am building a 50% goldwing sbach
MA
RE: elevator Q 3d flying
thanks for the reply david,yes i used to own a futaba 9chp and would the do the same ch 5, then i went to the equlizer from smart fly witch uses the elevator channel only,i did it because 1 servo would always lagg behind a bit more so on high rates so a friend recommended it. then i purchased a spectrum dx7 and used the smart fly but i want to do away with it in my new plane and i was curious if people still used them or not back five or so years ago they were a hot item.. thks again
My Feedback: (9)
I have a 9C and a 10C. I don't have a lag problem on either. Must be one of the lucky ones on the 9C I guess. 5 of the planes I have on it are dual elev servos. All of these have extreme throws. There are several ways to set the mix up. Maybe some of the ways cause the lag?
David
David
