MPI ACC134N 5A Voltage Regulator - 6/5.4V selectable
My Feedback: (76)
If you have any feed back on these regulators please put the input good or bad here... Iuse them in my 50cc Airplanes with Dual Batts and Dual Recievers..... I was just wondering if anyone else was using them my local hobby shop sold them to me told me they would be fine and then I had a few places online tell me that they where not that good here is the specs of them
Universal Connector• Input Range: 4.8V - 8.4V• Selectable Output: 5.95V or 5.4V• Current: 5A continuous, 10A peak @ 7.4V input and 5.95V output, Weight: 0.7oz
I run Fromeco batts one on each reciever and then each reciever has a alerion and a Elevator and then one of the recievers has the rudder and then other has the Throttle
Here is a picture of the regulator
RE: MPI ACC134N 5A Voltage Regulator - 6/5.4V selectable
Hi
Came across your post when searching for businesses who sell these regulators.
I've been using them pretty much as you have to include the redundancy. I've had them in two or three giant scale planes for a few years with no issues. I'm not a frequent flyer lately. I maybe fly 2 to 3 times a month. I've been preoccupied with work and a new workshop. I use Fromeco batteries as well. I also buy LG cells off Amazon and build my own packs. So far, so good.
I'm likely going to order some more. I don't like adjustable regulators. To me, that's just more complication which adds to the possibility of a failure. The fewer the components in the regulator circuit, the better.
Good luck with your regulators!
