35% setup question
My Feedback: (212)
NC
35% setup question
Finally was able to get the aeroworks extra 300 (red) 100cc airframe that I have been wanting for the last two years.Just need some experienced advice in setting it up.
I have the DA100 with standard dump mufflers, Just ordered two 2300ma A123 batteries for the Rx, I will be running redundant batteries on seperate switches. 7955's on the ailerons and elevators and (2)Futaba 9152's for the rudder.
My question (because I just don't have the 35% experience), do I need to use my batt-share with A123's? Also, will the smartfly power expander be of any benefit on this setup?
Thanks for the help.
My Feedback: (13)
RE: 35% setup question
I have a similar setup (using two A123 packs into one receiver). With my older receiver, I used two switches into two slots on the receiver. (One into the battery slot and one into any avaliable slot). Then a couple years ago I got the Spektrum "power-safe" receiver, so eliminated the two switches because with this receiver the batteries each plug directly to the receiver. Pretty much the same thing in the end.
So, no Bat-share, no Power expander, no regulators. The more channels on your transmitter and receiver, the better. Then you can put each servo on its own channel and avoid some "Y" connectors. If you have only a 5 channel receiver, then you will need some "Y" connectors or a power expander system.
FL
Don't think vary many people fly 35 presenters with 5 channel RX ??????
as for your question , it would depend on your Rx's current rating and your aircraft set up's maximum amp's , or if you have any problems syncing I'm thinking some of the PCM RX's are 9 amp? maxium ?
Probably you don't need the smart fly . but they are a nice pieces of hardware
that being said I think we all buy allot of things in this hobby " we don't 100 percent need as a assarary " it seems like the giant scale planes have alot of bling to them and the price add's up with the more bling you got . and there's always those people that need to have the best newest bling possible and they claim its justifiable in some means but its offen vary hard to find the true facts with out your own experimentation
so it's kinda a personal choice some times ....
and don't forget Y's on high current dobule batt's do have the chance to react probly to a massive amp draw IE I would'nt run High amps on a Y
My Feedback: (71)
I've had some signal interference issues with gas engines, even with pcm signal and "clean" installation.
You may want to consider 2.4 ghz system upgrade in the near future, much less risk of damaging this type of large, expensive planes.
That would be better money spent than on Power Expanders, not necessary on 100cc class planes. Your servos choices are good enough for 3d flying.
