Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
DLE 170 what is the best prop size to run
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 10-18-2011, 05:38 AM
Mullins
My Feedback: (20)
Default DLE 170 what is the best prop size to run
hello I have a 40% extra 260 with a new DLE 170 running a xoar 32-10 the problem im having is the at half throttle the prop is going supersonic does anyone know what size of two blade prop that I should run to fix my problem?
Jeff
Old 10-18-2011, 06:03 AM
bubbagates
My Feedback: (32)
bubbagates's Avatar
Default RE: DLE 170 what is the best prop size to run
30x13 CF prop is great for IMAC but you can send it supersonic at high throttle settings or a 32x12 CF (which is what I use). Since I do not fly 3D then this prop gives me the best of both worlds
The 30x13 will offer faster spool up in every case
Also, one thing about wood props, they are much less efficient that CF so they will get noisy fast as the blades actually flatten out.
I'm not sure of the DLE, but the DA170 peaks at around 6000 for torque (depending on exhaust system, more if you are using tuned pipes, not canisters) so you want to prop for that rpm. Find at what point the DLE max's torque (NOT MAX RPM) and prop for that
Old 10-22-2011, 03:30 PM
Taildragger726
Taildragger726's Avatar
I have had great results with the Falcon 30X13 Wide.
Old 10-23-2011, 07:16 PM
K-Bob
A Xoar 32X10? Heck my DA150 will make your ears bleed with one of those at 3/4 throttle. Try something in a Mejzlik 30X12 or one of the suggestions above.
Old 10-26-2011, 04:52 PM
Mullins
My Feedback: (20)
great thanks for all the help everyone I ordered a mejzlik 30-12 the light version it is a super nice and light prop havent got a chance to fly it yet but will this weekend
Jeff
