Peak Extra 330L 50cc
Hey guys,
Here is my second winter project, Peak Extra 330L.
Bought this one on special @ $ 689.00 with the DLE 55cc. No shipping fees, no duty fees, no customer broker fees no taxes....delivered to my door. Very poor packaging though...........
will be using;
servos Power HD 1214 TH , Coreless Titanium High Voltage Digital Double Ball Bearing
Weight: 2.3oz (65g) 6 v - 200oz/in (14kg/cm) 6 v - .14sec
Miracle switch, Dual Switch and Fuel Dot with dual charge jack.
RCexl Opto Gas Kill Switch
RCxel - Mini-Tach (mini tachometer)
LiFE Battery Packs - ( A123 2S Batteries) 3000mah receiver, 2100 mah ignition
Falcon Beech Wood Propeller 22x8 - break in prop, 22x10 sport flying prop,
23x8 high performance and 3D/Aerobatic
Futaba 7C 2.4
R617FS receiver
will be using;
Futaba 7C 2.4
R617FS receiver
NY
RE: Peak Extra 330L 50cc
Great Model. Packaging is a big cardboard box with all items wrapped and hot glued inside. Change the wing hinges, tail wheel and re-inforce the cowling around the prop shaft. I am on my second one, the first crashed by my own misjudgement. The good thing is that a new one was $419 shipped. As much fun as you can have with your pants on!
Kudos Peak Model!
Kudos Peak Model!
