Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
29% Katana-S ARF---Aeroworks!!!
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 01-26-2006, 06:31 PM
  #351
cstevec
cstevec's Avatar
Default RE: 29% Katana-S ARF---Aeroworks!!!
ORIGINAL: cobia
Cstevec did you get A chance to temp ZDZ 60 if so what did you get I have A ZDZ 50 mounted on my Kat now but if its going to be around 17 lbs I my go with A ZDZ 60 or Brison 4.2 How much prop Clearance with 24 inch.thanks fo the info cstevec.Roger
Not sure I understand your question. Engine temp after a flight? If so, it was 155 degrees (if I remember correctly) on a 80-85degree day. As to the prop clearance, I had CF gear from TnT on the last one & it is what I mounted on this one. Ground clearance with the 24" prop is very good, probably 3" with the plane in level position. I can't really tell you what the gear was made for, I bought it for a different plane but it fits the Katana better then the stock stuff & lighter too. Besides, it adds a little bling!
The first Katana I had I got used from a guy who built it with a ZDZ 50. He said it was tail heavy with that engine & didn't seem to hava enough power for good 3D. I had a ZDZ 50 & a ZDZ 60 so I decided to go with the larger engine. Believe me, the 60 is perfect with this plane. I can't comment on the 50 as I never flew that combination.
I was torn about the 1 or 2 servos in the wings deal (my last one had two) but after giving it some thought I am going to stick with 2. The old plane was very VERY precise when flying sequences so I figured why change what works. I know the second set of servos add about 6 oz. total weight to the plane but I would need to either buy new servos or go with slower servos if I were to use what I have in the shop if I were to go with just one. I have a Wild Hare composite Sukhoi to build before spring & I have to buy servos for that so I gotta draw the line somewhere.
Old 01-26-2006, 08:47 PM
  #352
cobia
My Feedback: (30)
Cstevec thanks for the info.was that A bluehead 60.
Old 01-26-2006, 10:47 PM
  #353
cstevec
cstevec's Avatar
Naaw, My ZDZ'z are all older models, before the Blue heads came out. I bought the 40 in 2003 & liked it well enough that I wound up with the 50 & the 60 too.
I have 3 Brisons as well, two 2.4's & a 3.2. They are really good engines. If I had a Brison 4.2 sitting around & I had a Katana, they would be a couple as fast as I could bolt 'em together, but thats just me. If you need a plane to put that 50 on & you have a few dollars after taxes, take a look at the new Wild Hare Cap 232. Thats gonna be a great plane for a 50.
Old 01-27-2006, 08:12 AM
  #354
cobia
My Feedback: (30)
well ZDZ says the 40 compares in power to some 50s how close is it to the brison 3.2.
Old 01-27-2006, 08:28 AM
  #355
cstevec
cstevec's Avatar
My 40 is strong enough to hover a Hanger 9 260 at about 1/3 throttle but I wouldn't want to try & fly the Kat with it. I don't think it is as strong as my 3.2. The biggest prop my 40 is comfortable with is a 21X8 Mezlyck. The 3.2 swings a 22X10 real well.
Old 01-27-2006, 10:50 AM
  #356
danielwidman79
Is there any video of the katana in action?
Old 01-27-2006, 10:58 AM
  #357
go vertical
some were early in this thred there is a vid
Old 01-27-2006, 08:00 PM
  #358
cobia
My Feedback: (30)
cstevec I got shot down on the 60 so IM stayin with ZDZ 50 for the Kat I also have A ZDZ 40 on H9 260 but Im going to strip it so I can put everything in my new GP Ultimate 160.I hope I can keep it around 15 lbs rtf I think the ZDZ 40 should do fine on 15 lb bipe.what did you tach the 40 with the 21/8.
Old 01-27-2006, 08:16 PM
  #359
cstevec
cstevec's Avatar
Never bothered to tach it. All I knew was it pulled real well. Should do great in that Ultimate. I wanted one of those but I have to many planes already.
Old 01-27-2006, 08:23 PM
  #360
cstevec
cstevec's Avatar
By the way. If you are going with an incowl muffler in the Kat, with the 50 you will want rudder on pull-pull, batteries up front & I would wait to install the elevator servos until the rest of the plane is built. My buddy balanced his with 11 oz. of lead in the cowl until he moved the elevator servos up under the hatch. With the ZDZ 50 in the nose & all three tail servos set up for pull-pull, the plane balanced perfect. Another solution might be CF or Fiberglass spinner. Bisson mufflers sell fiberglass spinners which is what I have on my WH 260 & they are light and cheaper then Carbon. Just a thought. (Or a warning about weight )
Old 01-29-2006, 07:31 AM
  #361
cobia
My Feedback: (30)
cstevec thinking obout the can on ZDZ 50 in the Kat do they add power or take away.
Old 01-29-2006, 02:31 PM
  #362
cstevec
cstevec's Avatar
Depends on the muffler. I had a side mount muffler on my 60 in a previous plane. When I switched to the can it was like a new engine. Compared to a pitts style, I don't know. Sure do quiet 'em down though.
Old 02-11-2006, 09:07 PM
  #363
rc bugman
My Feedback: (30)
Hi,
I need a little help with my 29% Katana. Where did you mount the receiver switches?
Thanks Elson
Old 02-11-2006, 09:26 PM
  #364
cobia
My Feedback: (30)
That depends on what engine and ignition you are you are going to use
Old 02-12-2006, 08:29 AM
  #365
cstevec
cstevec's Avatar
Directly behind the cowl, on either side of the fuse. The holes are not pre-cut so you will have to do that your self.
Old 02-12-2006, 08:52 AM
  #366
cobia
My Feedback: (30)
cstevec thats where mine are with ZDZ ignition or DA or 3W or any with shielded ignition .But I have had problems with Zen G38 my RX switch and Batt 8 inches from the engine I just measured it and thats about the only place to put the switches he should have 10 to 12 inches for A g62 if thats what he is going to use.
Old 02-12-2006, 09:00 AM
  #367
cstevec
cstevec's Avatar
Problem with the Katana is that big fat wing root. Takes up most of the fuse & don't leave much room for a switch. If ignition noise is an issue he could get creative & mount internally then use a pushrod to turn it on & off. Sometimes you have to think outside the box.
Old 02-12-2006, 04:11 PM
  #368
rc bugman
My Feedback: (30)
Hi,
I am using a 3W-48 twin on my Katana. I have it ready to go except for mounting the rx switches (dual rxs). I like to separate as far as possible from the engine/ignition but there is no place obvious to mount the switch except behind the wing trailing edge on the fuse. I was just curious what others had done.
Thanks Elson
Old 02-12-2006, 06:58 PM
  #369
cstevec
cstevec's Avatar
Thankfully, the newer ignition systems are very well shielded & most don't cause interference any more. I think 3W set the standard for that. You always want to take precautions & do a good range check with the engine running but I don't think you will have any problems.
Old 02-24-2006, 04:06 PM
  #370
xmarkman60
hey guys, does anybody know what color the blue is on the underside or on the cowl of the yellow 29% katana ? im thinking about painting my landing gear the same color blue?
Old 02-24-2006, 04:09 PM
  #371
xmarkman60
my hatch is warped pretty bad on the top piece of my katana, will canopy glue be rugged enough to hold it in place? any ideas?
Old 02-26-2006, 03:56 PM
  #372
cstevec
cstevec's Avatar
Guys, I finally finished my Katana. It took me forever 'cause I kept getting sidetracked, but it didn't turn out too bad.
Old 02-26-2006, 04:00 PM
  #373
rc bugman
My Feedback: (30)
Hi,
Looks great. What was the final wt.?
Elson
Old 02-26-2006, 05:09 PM
  #374
cstevec
cstevec's Avatar
To be honest, I dunno. I don't have a scale to weigh it with. No lightweight though I can tell you that. If I get some scales I'll let you know. The last one I built was a 3D monster though with the Exact same setup so if thats any indication, she should fly well.
Old 02-26-2006, 08:08 PM
  #375
cobia
My Feedback: (30)
cstevec very nice Kat do you know the name for the yellow and blue . did the stripes on the right wing come of very easy .Roger
