PULL PULL SETUP WITH FISHING LEADER LINE
NV
I understand that one can use fishing leader line for a pull pull setup in a 1/3 scale airplane. Has anyone had any experience with fishing leader line? If it does work, what would I be looking for ie manufacturer, diameter, test#, etc.?
My Feedback: (23)
RE: PULL PULL SETUP WITH FISHING LEADER LINE
Works Great, Less Filling.
Head to your local fishing supply store, or a K-Mart or WalMart. Get 40 pound test coated (with plastic) braided leader line. Pick up a package of ferrules (crimp tubes) while you're there.
Bigger plane? Use higher test leader.
My Feedback: (67)
IN
You may have a hard time finding the leader at you local walmart. Walmart carries it, but only in regions where there is salt water fishing going on. I was on vacation in florida before I ever found it at walmart! I stocked up on it too!
AZ
ORIGINAL: pettit
My Feedback: (90)
If you have an Academy Sports store in your area, you may find it there, or maybe at Boater's World. I live on the South Texas coast, but cant get it at Walmart here either.
TX
for a plane of that size i go to ace hardware and buy 1/16 garage door opener cable and solder it into a 4/40 threaded coupler and run that.i even use this on my 1/4 scale size sukoi and it won't streatch at all works great
WI
please tell me what is wrong with the DuBro 4-40 pull-pull set up with all the fittings that are included made from the same material that you are running all over the countryside looking for?
tom
tom
TX
not a thing wrong with it,just that ace is 1/4 mile from the house and 10 ft of cable cost me .60 cents and the couplers are what 2 dollars? how much to buy dubro's set up, just the way i do it
I use fishing line for all mine, much less expensive. Berkley and Surflon bot make nylon coated stainless steel braided line. For most uses 30 lb. test is more than sufficient although you can go all the way to 110 pound test..
I have even used plain nylon line with good success but prefer the steel braided if available. I was afraid the plain nylon would stretch but it did not.
NV
It's because I've got the Dubro setup in another plane that's no longer flyable (boy is it no longer flyable). So I've got all the pieces and parts and would like to save $16.00 if I can get the line for a couple of bucks.
If you can't get the SS coated leader material, can you get some high test Spider Wire or some other kelvar based fishing line. No stretch and high test.
Tom, nothing wrong with the DuBro kit, but you can get enuff materials for 5 or 10 planes for the cost of one kit.
Ed M.
Ed M.
WI
how much?
dubro part number rc 4-40 has a mfg suggested list of $ 8.25 for 15ft of cable and all fittings. I get mine at the LHS for $7.45 .
Its all there but no chasing all about town .
tom
tom
NV
Tower's Price $16.59
http://www2.towerhobbies.com/cgi-bin...?&I=LXEMF8&P=7
WA
I started with the Dubro kit then went on to making my own. Might I also suggest Shimano crimping pliers. I bought the small and normal pair and they are awesome.
