Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
RF Module compatibility?!
Old 03-13-2004 | 12:36 AM
Default RF Module compatibility?!
I have a Hitec Eclipse and a Futaba FF9. Q: Is it possible to swap RF modules between them without any problems?
Old 03-22-2004 | 12:07 AM
My Feedback: (8)
Default RE: RF Module compatibility?!
I am not sure about that, I have only swapped crystals. I do feel if your range does not change when you perform the swap, I would think it is fine. If you have any difference in range then you better call either Futaba or Hitec for the answer.
Chip
ORIGINAL: krokko
Old 03-22-2004 | 06:30 AM
My Feedback: (16)
WHile swapping modules is possible, it is not recommended.
DOing so is against the AMA rules and some say against the law.
ORIGINAL: krokko
