Power Box?? Good or Bad
My Feedback: (21)
RE: Power Box?? Good or Bad
For a 31% I don't think they are needed. If it were a 40% and you were running 13+ servos then they would be real helpful. I would just keep the 31% CA light and simple though
My Feedback: (21)
I have 4 Hitec 5645s and 1 Hitec 5945 and a fast servo on my throttle for my H9 Edge 540 running a single Rx battery and it has no problems with getting enough juice.
If your a Hitec guy you can buy the Hitec Programmer for $150 and never have to by a matchbox or matching device again. So long as you stick with the Hitecs. I had my friend program them and they are awesome, they don't even buzz because they are so perfectly aligned.
My Feedback: (21)
Current load, your receiver will be fine and a matchbox won't be needed at all. Thats what you use the programmer for, as long as they are perfectly in sinc then they will not drain a battery or fight eachother you should have no problems
