Aeroworks 36% Katana
OK
RE: Aeroworks 36% Katana
Never attached a pic before, but, here should be a pic of what I am talking about. That front area is where it came unglued. Is that where you would put a dowel?
OK
You can see from the picture (click to enlarge) where the arrow is pointing.. that is one of the 2 areas where the thick, but, light balsa goes into the stab The other area can be seen to as it looks the same in the picture. It looks like both of these inserts go into a hollow stab area, but, as you can see.. it would be impossible to get to unless I ripped off the current balsa piece.. the stab has some wood covering to it (the part that is covered in yellow and sticks out of the plane.. as you can see even on yours).
I can take any pics you want.. I can take them around 6-12 megapixels and provide a link from my personal web server. You could even see the grain in the wood if I did that. Let me know if you need anything like that.
NY
If you want to put dowels into the fin I don't see any way to get in there with out ripping the thing apart. I don't know what to tell you.
See if you can get the skinny from the guy who did the mod to his plane. Sorry I'm no help.
Dave
Dave
My 36% Kat weighs 28.75 lbs.....here's my setup.......
carbon gear (12 oz savings over stock)
ZDZ 100 NG on in cowl muff's, no cans (1.1 lbs lighter than the DA 100 on stock muffs)
2 2700 Nimh reciever
1 1440 Nimh for ignition
Kavan tires (about 1/2 the weight of the competitors)
foam pilot (weighs 1 oz.....no lie!!!!)
NO ADDITIONAL BRACING OR "BEEFING UP" ANYWHERE.....NOTHING EXTRA ADDED
even used a wood prop to save a few oz over the Mezjlicks
if you add in the weight of the stock gear and the extra pound for a DA, you're just shy of 31 lbs.....the scale doesn't lie......with that being said, I really like the way it flies, mine just needs to lose about 4 lbs to really make it do it's thing......
ORIGINAL: Smokey
When i called Aeroworks a few days ago. They said that the 36% Katana came in at 27 lbs with a DA 100 and nicad batteries. Everything done stock.
Smokey
Smokey
#31
OK
Thanks for that input. How hard do you fly it and how many flights do you have on it. I think I might not mess with it.. I might put wires on the back if anything. Just make sure I get glue down in where it came unglued all over that area nice and thick and go with it.
Could you give me some more info on some of your parts.. where did you get the kavan tires.. and was it the graphtec gear that they advertise for the aeroworks? Did you get another wing tube?
I think I will be heavier than even the da.. have a 3w106b2. I really have not idea.. just heard that somewhere.
I was thinking about trying to set up redundant/load balanced lith batteries and receiver.
I was also thinking about putting 2 servos in a swb tray for the rudder.
I dunno.. I need to get started on this.. just about have decided what to do.. just trying to get as many people as possible to weigh in. Don't find a high number of people flying this plane so don't have as much input on it as some of the other planes I have flown.
Again.. thanks for the input.. it makes me really happy to know someone did not have problems with this at all.
#32
AT the end some guy with honest weight.!!!!
Mine ended in 29 lbs with Carbon Fiber LG and canister[8D],Ahh 2X2350Mah Lithium ion Batery
#33
ORIGINAL: c016Y
#35
OK
That is some serious torque and speed!! That servo is huge!! ha. Had never really looked at it. Never really thought a lot about weight of servos, but, I guess if you put 2 servos in a tray it will come out to about 5 oz as does the 5735. Maybe it would be a good idea to get a 8611 or that new hs 5955tg http://www.hitecrcd.com/product_fs.htm .. it is only 2 oz and at 4.8 has 250 oz of torque and .19 60 degree. I could get it for just over $100 and I was going to gang 2 of my 5945's that cost me about $55 each. hmm.. same price.. less weight.. never really thought about it that way.
Is there any other reason to gange the servos outside of torque? Do people do it for redundancy? I guess if one goes out the other could get it back down? Looks like a pain though.
#37
$55 for HS 5945's? I don't think so....5645's but not the 5945....cheapest I've ever seen the 5945's is $79, and it looks like Hitec has raised the price a little lately....if you get them for $55, lemme' know where.....
#38
OK
I called in to chief. There was a mixup and I had purchased the red katana over the phone. Finished the order.. it was the yellow. Got to talking and I got the bundle for katana and 8 5645's for 1090.. here is from the email invoice:
> >Qty. xPrice =SubTotal SKUID: Name
> > 1 1090.00 1090.00 AW_36KATR_HIT5645-JRHIT
> > Airplane Gas 36% Katana ARF Red with (8)
Then I asked for the upgrade for $20 each for the 5945's. At the time the kit was 795 instead of 759. Ok.. 1090-795=295/8=36.8 for the 5645 + 20 each for the 5945 = 56.8 each.
Right now it is about the same deal, but, they say $25 upgrade for each and instead of 1090 it is 1149.
I thought it was a fantastic deal. I was only going to get the airplane, but, could not pass up the servo pricing.
#39
The plane is like much ARF you have to work on it.
The only problem that i have now is that the plane is way tail heavy but easy handle. Very good in 3D and take your time with the cover.
Here another pic.
Oscar Silfa
Here another pic.
Oscar Silfa
#40
OK
Wow.. looks great. What is that big box by the rudder servo?
Also.. when you say you worked with yours.. what all did you do? Just curious.
#41
The big box is an Emcotec DPSI mini(Dual power servo interface).
About the change,i'm going to move the rudder bellcrank in front of the rudder servos,change the elevator servos extensions because i use the 18 gauge and is 1.5 onz more heavy than JR extensions, i acctually have the extra heavy duty linkage in the elevators servos and i'm going to change to heavy duty.
My carbon fiber LG was broke in the maiden flight but graphtech is going to send me a new one under warranty.
That's for the moment.
Oscar Silfa
Oscar Silfa
#44
OK
so osilfa.. are you pretty much saying that you did not make any structural changes during the building process.. or did you do some things like glue down x extra well and put dowels in y to make it stronger.. did you do any of that? Just curious your building experiences on this project and how you felt about the design of the plane. I am trying to poll some more experience resources on this project since it is my first large scale and I have nothing to compare to.
Thanks for the pics Dave and Osilfa. That helps a lot on the setup ideas.
#47
BC, CANADA
well guys i have picked up a red one from aeroworks a week ago last one in stock . and i am putting in a 3w 120cc and a 30/10 prop
aeroworks says it won't mind the little extra weight in the nose . i have just started putting it together everything fits just fine . i am looking forward to flying this it looks great.
