Construction question
My Feedback: (61)
RE: Construction question
Use PFM or Shoe Goo .. works a lot better than canopy glue and its clear when it goes on and when it dries. Stronger than anything out there and its removable if you need to do so.
PFM is hard to find, but well worth the time if you can get it.. it is thick and it "flows" into gaps, etc. I put a small bead around the canopy, drop it in place and tape to congform to the fuse.. I end up with a gapless fit every time. If any glue gets out from underneath while curing, let it dry and roll it off.
Amazing stuff!
DP
Amazing stuff!
DP
