Comp 2.6 yak pull pull question
My Feedback: (38)
RE: Comp 2.6 yak pull pull question
Mike:
Everybody's measurements are different due to servo location, servo arm width etc. The best way is to draw it out on paper. Basically what you do is draw the bottom of the fuselage on the paper (with a center line) from the servo arm location to the rudder post. Measure the width of the servo arm, the length from the servo arm to the rudder post and the width of the rudder post and transfer these to paper using your center line. Then measure the width between the holes on the rudder servo arms, I think it is 4". Then you simply draw a line from the the servo arm hole location to the rudder arm location over your fuselage drawing. This will show you exactly where the cables will exit your fuselage. LOL
Paul
Paul
