Stay tuned, Extreme Aircraft Extra 300 on the way
#176
IL
RE: Stay tuned, Extreme Aircraft Extra 300 on the way
"Batteries seem pretty far forward"?... I put the ignition batterie in the noise for balance... The receiver batteries are in the "CG" because I remove the FUSELAGE DECK, CANOPY DECK, CANOPY BACK PLATE, FUEL TANK DECK AND PUT ONLY ONE SERVO FOR AILERON... Remenber the ailerons servos are forward the CG. see the pictures again... I will post more pictures tomorrow...
#180
My Feedback: (99)
TX
ORIGINAL: ICE_MAN
Hey,
Nice rudder tray! How much would it cost for you to make me one? Or are you even interested?
Hey,
#183
KY
Oh sorry I thought you were asking the size.. Woops. Yes its the Extreme Aircraft..
If anyone has seen all 3, is there any really major change between the 3 brands to make the performance and prices different from one another? Just curious
#184
IL
I will make the rudder tray...
is for 34% Extra?
what brand of servo? HITEC 5955 or JR 8611A?
Do you like w/ AirWild EFP Bellcrank or direct drive?
or I will include all if you can see in the picture servo tray... included the cable, AirWild Cable Attach Fitting, AirWild EFP Bellcrank, JR or HITECT servo, Titanium Pro-Links 2" and four DU-BRO 1/4 Heavy Duty Ball Links
is for 34% Extra?
#185
KY
How much for it with all the pictured stuff? I Have a HS 5955 that will go in it. not quite ready to buy yet, but I'm very intersted.
#186
My Feedback: (99)
TX
guilletnt,
What is the width of the arm your using for the p-p on the rudder and are you crossing or going straight out the back.
#187
My Feedback: (99)
TX
ORIGINAL: DENNIS C
guilletnt,
guilletnt,
Stupid me.....looks as if your going straight out. with the straight arm on the servo.
How is this set up working out do you have any slack in the cables.
#191
IL
-Four AirWild Cable Attach Fitting, #4-40 : $2.99
-One Pull-Pull Cable, 30 ft., 60 lb. : $5.00
-One AirWild EFP Bellcrank Assembly, 5 in. : $17.50
-Two 1/4 HD Ball Link : $3.50
-One 2.5'', Full Arm, Hitec ''+'' : $8.95
-One Carbon Nomex servo Tray same configuration if you see in the picture
ready to instal in the fuselage (include the four screws) :$40.00+ $15 Two days shipping.
I will include the Air Wild invoice...
Total: $92.94 + Air Wild Shipping charges.
http://www.rcuniverse.com/market/item.cfm?itemid=141622
#193
IN
Wouldn't a simple pull-pull cable system hooked directly to the servo arm be a lot simpler, less slop, less weight, less $ and work at least as well? Of course, I'm missing the Bling-factor of the atomic-powered fly swatter.....
#194
MN
Me and a buddy were talking about this and it would seem this system has taken the load of the cables completely off of the servo. Every time you move the rudder it put tension on the servo output, but this setup issolates it to the bellcrank. We just picked up our planes today and they are awesome!!
#197
IN
ORIGINAL: budgetdude
#198
MN
You must not jam the sticks hard enough You have a point but he is only running 1 servo which is a relatively new alternative in this size airplane, besides anything to help increase service life and add some cool points is worth it. Any how i just got mine and all I can say is whoa, this thing is nice. I have had a 27% before but this thing is huge. I cant believe this was 500. I remember the giant scale EZ arfs like the Diablo went for like 900 bucks back in the day and it was like a 72 inch hunk of foam and plastic.
#199
IL
The first flow is ok... a little tail heavy... I need move the batteries maybe 3" in front the CG. and remove some weight the fuselage... next saturday is the 3D testing day... I will put the next sunday pictures and video the my baby in action...
#200
MN
Guys,
I drove out to RC Superstore yesterday, and picked up two of these, (saved myself $200 shipping less $25 in gas). For $500 a piece you just can't beat it.
Anyway the proprieter was not there but I ended up dealing with his father, grandfather, and grandmother, I think. Super nice people, I ended up shooting the breeze with them for a while.
Guilletnt-Are you planning on attending any of the IMAC events in your area next summer? Budgetdude and I are going to try and get to at least one in your area, as well as the one in Waukesha, WI. Also, did you replace the aluminum bar used for the stabilizer locater pin, with CF? Way back there, this may have at least some effect.
Later
Later
