OS 320 4 cylinder engin for 1/4 scale CAP 10B
My Feedback: (17)
MO
I have a Yellow Aircraft CAP 10B that weighs 17 lbs. A freind has an OS 320 4 cylinder engine for sale and I trial fitted it into the cowl and it fits fine. My question is does the OS 320 4 clinder have the power to pull an airplane that has a 40 oz/square foot wing loading?
Mike
Mike
My Feedback: (7)
RE: OS 320 4 cylinder engin for 1/4 scale CAP 10B
ORIGINAL: PA28R201
Mike
Mike
A lot depends on the prop you use also, and if you want to do 3d such hovering, be expecially carefull with the cooling of the rear cylinders.
Roger
Are You ready for the build season
