Engine Thrust
OH
Chip,
I've heard you say that you no longer build right thrust and down thrust into your planes. You now add right and down thrust using programmable mixes. I'm building a couple of Focus IIs. Would you recommend that I mount the engine perfectly straight or should I use the right/down thrust recommended in the instructions? Are there any situations where I shouldn't build them straight and correct with mixes?
P.S. I posted this message several months ago and didn't get a reply from you so I reposted it.
Ron
Ron
