Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
40% MX2
Old 01-21-2006, 12:40 PM
JAS
JAS's Avatar
Default 40% MX2
I know there was a thread somewhere on here about people wanting a new design, other than a Yak or Extra, and a few knew about the MX2. Well, the choice, at least in 40%ers is now available. I’m not plugging the company, I’m plugging the airplane. Here’s the link to it. [link=http://www.composite-arf.com/ar/Product?651000]MX2[/link]
Jason
Old 01-21-2006, 12:54 PM
JAS
JAS's Avatar
Default RE: 40% MX2
Some pics...
ID:	392132   Click image for larger version
ID:	392133   Click image for larger version
Old 01-22-2006, 12:52 AM
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
Default RE: 40% MX2
That is wicked looking. When will we be seeing them in the states? I LOVE GREEN! Too cool!
Joe
Old 01-22-2006, 01:16 AM
Darrinc
Default RE: 40% MX2
Looks like a great place for a 3W 106QS on full length tuned pipes. I bet with a little thinking, you could get it down to 33lbs, which is the same weight of a lot of 35% Cardens. (not saying anything bad about Cardens)
With the wing area, it would be like a big foamy at that weight!!!!!
Too much fun, and you would not have to drop the money to upgrade your engine. With those pipes you can run a 30x10 prop!
I would think that any 106 owner would have to look hard at this option.
Good show Comp-Arf!
Old 01-22-2006, 01:29 AM
flyinrazrback
My Feedback: (69)
flyinrazrback's Avatar
Default RE: 40% MX2
I am thinking hard on one of these, but most likely with a 3w 157 or kroma 180
Old 01-22-2006, 05:14 AM
JAS
JAS's Avatar
Default RE: 40% MX2
The first 1 is actually already sold and due to land in Feb. The next few (also Red or Yellow in place of the Green, or custom colors) will land in March. No numbers on how many or which one's are coming, but I would imagine that the ones that are ordered and paid for, will be on the next boat.
A 106 with full pipes should work. I remember when Dave VonLinsowe took one of his TOC 202's and pulled every other thing out of it and flew it with a DA-100. He said it was a big kite... At 29lbs, I wouldn't guess otherwise.
Old 01-22-2006, 09:37 AM
Hammbone
My Feedback: (309)
Default RE: 40% MX2
Looks good and I like that scheme.
The plane is capable of balancing properly with either a 100cc engine or a 150cc engine? How is that possible? It doesn't look like there are 2 wing positions.
Jim
Old 01-22-2006, 01:25 PM
SunShyne
My Feedback: (68)
SunShyne's Avatar
Default RE: 40% MX2
Wild hare has one under development as well, im pretty sure its not a 40% but something more like a 35%. Regardless its nice to see another type of aircraft being modeled for us to enjoy
Wish CAP's would make a comeback
matt
Old 01-22-2006, 02:03 PM
Carroll-RCU
My Feedback: (43)
Default RE: 40% MX2
Hey Charles, I replied to your e-mail but it came back as undeliverable!
Old 01-22-2006, 03:16 PM
Tired Old Man
Default RE: 40% MX2
Darrinc
Uisng a BME 110 instead of the 3W would probably get it down to 31 pounds. Like you always say, lighter DOES fly better[8D] With the 110, ya prolly wouldn't need the weight of the pipes to pick up the power
Old 01-22-2006, 03:26 PM
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
Default RE: 40% MX2
I wanna big kite!!!! DA100 for me on pipes. THE GREEN SCENE!!!Ahhhhhhhhh! Comp-arf, your killin me! Between that or the lightening! Freakin airplane pourn!
JAS, is there any reason that this airframe could not be built to 29lbs like Dave did with the giles years ago? Did he have a special light one? Maybe even find skorepa or other carbon pipes!
THe video looks very promising. The checkers on the bottow look just a bit too busy for me but what the heck, I could get over that!~).
Joe Kelley
Old 01-22-2006, 03:28 PM
flyinrazrback
My Feedback: (69)
Default RE: 40% MX2
I wouldnt go with a 100cc anything on the plane, just for the fact that it will have enough power at 31-33lbs, but not completely unlimited. I had a Carden 40% giles that was around 34lbs with a 3w 150, and it was ballistic, as I like it. Tuned pipes do add weight, but I know at least with the 3w 106 that motor is a different animal with them. Guess no one has tried a 110 with full pipes yet. I think if I go this route I will try the Kroma 180 to try something else. Another good choice I would think would be a zdz 160, about the power of a DA, but 1lb less or so.
Old 01-22-2006, 05:14 PM
JWilliams
Default RE: 40% MX2
This plane debuted at Oshkosh about 2 or 3 years ago. Curious to see how it flies since the wing/tail/engine are so off to each other.
Jeff Williams
Old 01-22-2006, 05:18 PM
Tired Old Man
Default RE: 40% MX2
Actually, I agree with you. I was just upsetting the traditional DA/3W, "that's what I have, ergo that's the best" manufacturer mindset.
Old 01-22-2006, 10:18 PM
Darrinc
Default RE: 40% MX2
The 110 is a great engine and so is the DA100, they just not have the power of a 3W106QS from my personal experiance. But if they can spin a 30X10 with authority on pipes, then they will work great for this application too.
I have seen personally seen many 31lb to 34lb Carden's being completly unlimited without pipes on their 100's btw.
This plane just seems a little small for a 150, and a little big for 100, so creativity will be needed to make this plane a value at it's size.
Old 01-22-2006, 11:05 PM
AU cary
Default RE: 40% MX2
i too saw this aircraft at KOSH. it is a giles 202 with a wing mod. and it does look bad ass.
Old 01-22-2006, 11:37 PM
RTK
RTK's Avatar
Default RE: 40% MX2
The stronger 100cc class engines should be able to pull about 60+ lbs static. That being said, if done light that still is about 1.8:1 thrust/weight.
More is better, but that still should be unlimited.
Old 01-23-2006, 12:53 AM
bwick
Default RE: 40% MX2
A 150 would be insane on this thing, giving it the great power:weight ratio you'd want for IMAC and especially quick and exciting freestyles. Possibly a big 40% sized plane with the quickness and agility of a 35%'er.
Old 01-23-2006, 01:11 AM
Tired Old Man
Default RE: 40% MX2
Don't forget that a 40% Giles would be sized comparable to a 35-36% Extra. It's a smaller plane in full scale than a Cap, Edge, or Extra. A little effort to keep the plane as light as possible with a strong engine would go a long way to making it a true performer. Now I've heard rumors that a certain "cult" maker of engines may be coming out with something between the current 100/110's and 150's 'fore too long. Now that I think about it, I believe Taurus may have something currently available along those lines now. Not positive, tho.
Old 01-23-2006, 07:49 AM
jsm77777
Default RE: 40% MX2
It's not a Giles 202. It's closer to the Giles G-300, as the MX2 has a 6 cylinder engine, versus the 4 cylinder on the 202, and 200. Also the wing platform is different than the Giles, as it's a double taper wing like an Extra or Cap 232. The tail surfaces are also larger than on the 202. I got a good look at this plane at Oshkosh 2004, and really would have liked to fly it. Scott
Old 01-23-2006, 09:42 AM
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
Default RE: 40% MX2
I sure would like to get my hands on this model, and do some EXTENSIVE testing!hahaha! 100-150, whatever. It looks really fun., Great job comp-arf! Now how about a lightening in the p120 or p60 size!haha!~).ooooo, and in green!!! YEA!
Joe
Old 01-23-2006, 11:03 PM
AU cary
Default RE: 40% MX2
im not going to argue about this but i am almost positive it is a 202 fuse. all the giles had 4 cyl. engines. this was the entire idea of the plane itself. cheap, well cheaper acro. the 300 was a one seat airplane, the 202 was 2 seats. the MX2 is a two seat airplane. i think it might have a 6 cyl. lyc. i dont know much but i am sure its not a 300 fuse. im done
here is the real deal holly field http://www.mx2aircraft.com/site.html
Old 01-24-2006, 07:51 AM
jsm77777
Default RE: 40% MX2
You are somewhat correct. The MX2 is not a stock 202 fuse, it's longer to accomodate the 6 cylinder engine. Yes' the G-300 is a single seater, but the MX2's fuselage is closer to that than the 202. The G-300 really was a 202 with the lengthened fuse to accomodate the bigger engine, and front seat removed. MX2 wing and tail are different also. Scott
Old 01-24-2006, 09:25 AM
mu2driver
My Feedback: (15)
mu2driver's Avatar
Default RE: 40% MX2
Nice plane indeed...
I remember when I was 10 I got a Kawasaki KD100...it was the same Green....did you see the blast off from a hover...cant you say Rocket Ship...going to the moon
Im thinkin DA200...lol j/k
Old 01-25-2006, 12:41 AM
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
Default RE: 40% MX2
Have the MX2 bathed, and brought to me!haha!
I remember that kawasaki green too! I love that green!
It sure looks punchy get off the ground like that. That's what I like. !~)
Joe
