1/3 Turbo Ravin Kit. Power Plant Question
My Feedback: (39)
CA
Hey Guys,
I am testing the waters here to see if there would be interest in a Turbo prop version of a 1/3 scale Turbo Raven kit.
Currently the plane is powered by a Mac 85 twin but I am interested in pursuing a functional turboprop; possibly a MW54 or similar turbine. I have been told that a small turbine can produce a huge amount of static thrust. One of my concerns is what would the lag be from Min to Full throttle?
If the turbo prop version pans out I would like to then add a functional proportional prop.
Please let me know if this sounds interesting to you or if you have any ideas / suggestions.
Thank you for your time.
Sincerely
David Mosher.
Sincerely
David Mosher.
Do you produce that kit?? What are the specs, does it 3D and all that good stuff??I have always liked the turbo raven, but it has never been made availiable.
Ideas for the turbo prop,
dont spool the turbine, run on pitch only because the lag willl be tremendous. It'll be fun trying to get all of that equipment into the cowl for the gearing and such.
Whats the price on the kit?
My Feedback: (39)
CA
Hello,
Yes I do now produce the kit. The wing is 102 inches. You can go to http://pages.sbcglobal.net/davidmosher/index.html for more info.
Currently the short kit is 750 with a deluxe kit to follow but that will depend on how well the short kit is received.
I have been wondering about using a similar set up as a helicopter where the RpM is constant with a swash plate type device for prop pitch. Maybe I can get JD Enterprises to create an ecu that will allow the pilot to set the RPM through a modal switch and then back for landings.
What do you think?
David.
What do you think?
David.
David, see below link to another section of RCU. I guy in Austria has a turbo prop on Cap. Very long thread. I'm sure can get lots of info form it.
http://www.rcuniverse.com/showthread...268&forumid=59]
CA
Turbo Raven
Hi David
I see you have the Turbo Raven done, WOW it really looks fantastic and it's a perfect aircraft for the JDE Turbo prop, Can't wait to see it go let me know when we can get together to test fit the engine in it.
BRG's
Dennis
JDE
BRG's
Dennis
JDE
That simulated Turbo exhaust looks great with the round cylinders. When are you going to have some video of this bird?
My Feedback: (39)
CA
Raven
Hi guys,
Thanks for the kind works and the advice. I will take a look at thread about the Cap Turboprop.
Dennis, I should have a fuse for us to look at by the end of the week.
Thanks again.
David.
Thanks again.
David.
My Feedback: (39)
CA
Video of the Raven
Hello,
I have video of the Raven in flight; currently I am putting together a more finalized web site that will have detailed pictures and video.
If you have any questions or suggestions please feel free to contact me.
David.
David.
Raven - +Mac 85
Hi David,
Great looking plane.You mentioned that you have a Mac 85 in it.How much does it weigh & how is the performance...unlimited vertical,can it hover,etc.?
Thanks,EJB
Thanks,EJB
My Feedback: (39)
CA
Hello EJB,
The Mac 85 performs very well; it seems to get stronger the more we run the engine. Currently the Raven is 26 Lbs Dry. The Mac will allow the Raven to hover but not power out quickly. I have been looking at a DA100 which should give the Raven great 3D capability.
Take Care
David.
Take Care
David.
