composite ARF.
composite ARF.
Hello,
I want to a buy the 2.6m composite ARF but i'm torn between the extra and yak-55. Which do you think flies better?
What engine works greatest with this kind of plane without causing any problems?
CO
RE: composite ARF.
Get the yak if you like 3d and the extra if you are into imac. Once again every plane has its advantages. If I were you I would get the yak but yet again my opinion. Put a bme 110 in either.
My Feedback: (51)
RE: composite ARF.
qabandi
I own both same as flyinrazrback.
Get the Yak for IMAC it's Up lines and Down lines are the same speed because of the large cowling.
3D the Yak is very nice as well.
The Extra is a Faster machine and has a sleek profile in the Air she performs Snaps a bit sharper.
Hope this helps U a bit.
Ian
My Feedback: (15)
RE: composite ARF.
ORIGINAL: Mr.Extra 260
RE: composite ARF.
Thanks guys for the feedback it was helpful. i went ahead and took the yak. now i'm torn between the DA100 and 3W106 for the engine they are both powerful, but which one works better with the yak and the carburator doesn't get affected by the invert and knife edges, as the yak has a large cowl opening and air fluctuation.
My Feedback: (69)
AR
RE: composite ARF.
If you want monster power, go with the 3w 106 and a set of KS 1060 tuned pipes. Unreal power for any class of competition. No airflow problems for the carb on my 3w, just ran the vent tube off the carb back into the fuse. No baffling either, and ran pretty cool. A DA would work as wll, but if you went that route I would still do the KS 1060 pipes as the yak is a draggy airframe and needs the power IMO.
