zdz80 super 35%yak
zdz80 super 35%yak
I have a friend with a zdz80 on a 33% aeroworks yak 200' above sea level it has insane power, or really good anyways.Do you guys think it will 3d a 35% yak?He h0vers about 1/4 throttle..........i think..................................thanks
My Feedback: (69)
AR
RE: zdz80 super 35%yak
I would say it would be ok if you used a zdz super 80 and full length pipe. I have flown the 75cc version (as recent as yesterday) with a super 80 and stock mufflers and while it does have plenty of power, it is not ballistic. It weighs about 24lbs dry. So, IMO the only way you are going to get good performance out of the 100cc yak with a 80, is by using the super 80 and full pipe as it will make a tad more power than a DA 100 on stock mufflers. However, if you run a can or stock muffler I would say no way. You would also have to do everything possible to keep it light, ie carbon gear, wingtube, simple electronics setup, etc. Would I do it? No, I would put a 100cc at minimum on it. But, a super 80 on a pipe will fly it good, just not ballistic, stock muffer forget about it.
My Feedback: (17)
QC, CANADA
profile540, if you goal is only 3D, forget de super ZDZ-80 and go for BME 115 or a strong 100CC twin with canisters in a 35%, 25-27 lbs plane.
If you're on budget, go with the super ZDZ80 and any 33% in 22-24 lbs will be a perfect match for 3D.
Don't forget the Yaks have more drag than other planes and you'll need more power for the same weight to get out of troubles quickly
Dan
Dan
