reversing El. servos
TN
I am building a 50cc edge and am using a 7cap radio. I either have to turn the servo around or point the horn one up and then one down to get the EL. to work in the same direction. On this one that will not work and I am going to have to buy a reversing y harness. What is the best reversing y harness? Most of the time I use Expert, but I want the best for this one. I am going all digital servos. Or by some slim chance does anyone have any idea on a better way to get them in the same direction. On the older servo you could reverse the servo, but no more .
My Feedback: (16)
GA
RE: reversing El. servos
The best way is to get Hitec Digitals and the programmer.
What I have done in the past is go get a Futaba and a Hitec servo on the elevator.
They will move in opposite directions.
Just make sure that the speed is the same.
Not having the same torque will not be a problem so long as the torque of each servo is greater than specified.
ORIGINAL: freebird1
My Feedback: (41)
Some of the servos are available with a reverse rotation, other possibilities already mentioned are good ones, but I don't like the idea of Y-harnesses...
The other possibility would be to use a Matchbox, they can reverse servo travel as well as match endpoints and neutrals and they are less money than a Hitec programmer, less hassle than ordering a special servo and I prefer to use same brand/model servos on control surfaces.
The Matchbox can also provide power directly from the battery should you need it for high current throughput, but they are about $60 whether you buy JR or Futaba.
TN
ORIGINAL: Zeeb
As long as the trims work equally when the servos are set up on different channels that method works just fine. Some systems don't match the trims. That's where a Matchbox, Equalizer, or the Futaba specific products shine. Reversing Wye harnesses often have their own issues with different speeds and trim changes as they heat up. A reversing Wye harness is for me not the way to go.
GA
I ran reversing Y harnesses for years until finally one failed on me. They have been known to do that for many people. On a giant scale plane I would use a matchbox or a Emcotec Mini system. I use hitech digitals with the programmer and also use the Emcotec system particularly if you running high voltage.
My Feedback: (15)
NC
He said hes using a Futaba 7cap and you CANNOT run dual elevators without some device or a reversed servo as it will not trim the slave channel, why Futaba did that I do not know, in reality its no better than a six
Its on their web page
AK
On a 7cap,,useing 2 and 7,the trim only works one elv,,but it flys fine,,no problem,,1 and 6 the trim work on both for the ail,,in a 9cap when you split the elv,you have to use 2 and 7,if you want all the mixes to work right,and the trims do work on both on a 9cap set up this way,if you use any other channel but 7 for the second elv,on a 9cap,the mixes wont work on both elv.
NdFrSpeed
NdFrSpeed
The individual that started this thread is clearly just getting started in Giant Scale. This is a nice step to be making and usually provides great rewards to those involved. The downside is that the individual is still think on a much smaller scale. It's now time to broaden horizons and begin looking at, and using, equipment that's designed to meet the more specialized needs of larger aircraft. This could be an excellent time to begin learning about all the tools that are available to those that get into bigger planes.
My Feedback: (15)
NC
[quote][On a 7cap,,useing 2 and 7,the trim only works on elv,,but it flys fine,,no problem/quote]
I repeat you will have no trim on one half.
Ndrfspeed how you fly fine with no trim on one channel is up to you but its not exactly good advice
Read it yourself http://www.futaba-rc.com/faq/faq-7c-q763.html
I agree with Silversurfer.....in the long run getting a decent radio will save money and wasted effort.
AK
Got news for you it works just fine 1 Elv.and i know the trim on the 7CAP only works on one,,thats what i said,and it works just fine,,.i know what Futaba says,,they also said i cant do what im doing with my 9CAP till the Tech i was talking to went and got one and i told him how to set it up,,there suppose to be correcting the manual on the 9CAP as well.
NdFrSpeed
NdFrSpeed
TN
Thanks gang
I have had several 1/4 and a few bigger bird close 30%. I really need to get a new radio, but will do that when funds become available. This is the first one that requires reversing one of the El. servos. I have used a Y, but did not really like it. I think I will go with a matchbox. The only one I can find is a JR. I was going to buy it. I was thinking will it work with a Futaba RX. I do not think it will, but I really do not know. What is a good matchbox for a futaba RX.
Thanks again
Thanks again
TN
Ok I think I have found what I need. I just bought a Futaba MSA-10 10SX Synchronizer. $59.99. I think it is just what I need and can synchronize 4 servos too.
Thanks again
Thanks again
My Feedback: (10)
freebird1,
Glad you found a fix. What I do is when I get a plane and find out I need to have one servo reversed I call Servo City. This is where I buy my servos and other goodies. They will reverse the servo for you at no cost to you. Just something to keep in mind for the next time.
TN
Thanks I will keep that in mind. Do they have a web site. I know we use to do this our self years ago, but the new servos are over my head. I opened one and took one look and close it up.
TN
ORIGINAL: freebird1
My Feedback: (18)
I have been using one 8611 and one 8611 reversed on my elevators for all my planes for a while now. There are other benifits to this setup, can anyone name them?!~)
joe
joe
ORIGINAL: Zippi
freebird1,
freebird1,
