Extreme Flight 88" Yak - Build and Fly
My Feedback: (42)
RE: Extreme Flight 88
Isn't it amazing.... I remember some years ago watching a guy hover a plane....might have been the first time I saw an RC giant hover....it was a video...when he punched out he also nosed it over so it would start using the wings.....wonder what his thrust to weight was? Nowadays we are pushing the 2-1 rocket like escape.....yeah I saw LXCoup with his DA120 powered EF-110 on a JC 28-10 at about 6500 rpm.....he punched go and it was like a rocket launch, straight up.... We have come a long way..
I'm using Red Line at 40 to 1, after 4 gallons of Lawn Boy Ashless at 30 to 1. I should also check the gap on the plug, which I hear should be at .018. It made a big difference on the Funtana. Didn't know about the difference in US octane compared to Europe; thanks for the continued help. This is my first 50cc and it is definitely a work in progress. My goal for a rocket may be misplaced and really not needed for my style of flying. Just looking to get the best I can within the stock muffler configuration. My other plane is a Funtana 125 with a 30cc gasser and it has strong vertical, but isn't nearly as much fun to fly.
My Feedback: (9)
MO
Need helps guys:
I have an 88in YAK. I need about an quarter inch up elevator for level flight. At full throttle it dies. I need again about an quarter inch right rudder for straight flight. My CG is on the back side of the recommended mark. The incidence meter won't be here for another week. I need suggestions please.[sm=punching.gif][sm=punching.gif]
My Feedback: (41)
Wait for the incidence meter. Check everything including engine thrust. Should have a little right thrust in the firewall. Engine is offset a small fraction of an inch to the left (1/8th to 1/4"). Are you using good aluminum standoffs? If the stand off's are home made the thrust could be off.
Richen the high needle. It may be too lean and running out of fuel in the mix.
NJ
ORIGINAL: ahylt
Need helps guys:
Need helps guys:
Mine flies with 5 clicks of up elevator trim, as does a friend with another EF 88" Yak. I thought the incidence might be off, since the cg provides near hands off inverted and upright flight. Didn't want to mess with it, sincel it flies so well as is. Will adjusting incidence make much difference?
My Feedback: (41)
ORIGINAL: Slow and Steady
Mine flies with 5 clicks of up elevator trim, as does a friend with another EF 88'' Yak. I thought the incidence might be off, since the cg provides near hands off inverted and upright flight. Didn't want to mess with it, sincel it flies so well as is. Will adjusting incidence make much difference?
My Feedback: (9)
MO
Oops typo. The plane dives when i go full throttle not dies. I am using the dle 55 with the stock standoffs. Everybody talks how good this flies but my ef 88 edge flies much better, just not happy with it right now. guess i will wait for the incidence meter and see if it straightens out. Thanks guys
I am definitely enjoying this plane. The blenders, which I just learned are awesome and totally predictable. The inverted flat spins are FLAT! I think I will leave well enough alone regarding the incidence. Thanks for the advise. This is my first 50cc plane and its ability to fly in 15+ MPH winds is great. 82 flights in two months and loving it!
AHYLT, I look forward to hearing of your incidence results. Hopefully, the issue is quickly resolved.
My Feedback: (13)
OH
i had two EF yaks,both needed the incidence tweak a little on the stabs to make them perfect.if you don't mind flying with a little trim, that is all well and good.it's just nice ( for me) to take your hands off the sticks and it flies straight,flat and true with out the control surfaces fighting each other.
i do this on every ARF i buy and it a pretty common problem on all of them,no one builds the way you would build one for your self.
My Feedback: (41)
ORIGINAL: closetguy
PS: Another note. My 110 came with a incidence checking list. All of them were either 0, 0.1, -0.1, or 0.2. I'd be a little hesitant to make these any better because I don't think I'd have an accurate enough meter or process to do it. One could argue that I might even make them worse. Just some food for thought. It says on my Robart incidence meter instructions that if everything is under a 1/4 degree don't mess with it.
My Feedback: (41)
ORIGINAL: ahylt
Any ideas?
At Luffenham Airfield where we fly we have never had to keep the noise down so to speak but due to a local complaint the club has adopted the BMFA method of testing ie no more than 82db at 7m aircraft place to N,S,E and W etc.
My set up is DLE55 with full pipe MTW (was advised to get this pipe on RCU and has been brilliant) Carbon prop 23x8.
Anyone got suggestions to make the magic 82db? currently mine at 7m is 89-90db. Now when I tried a 23x10 carbon the engine got a bit hot.
Over to your suggestions!
My Feedback: (9)
MO
my yak came with the incedence paper to, they were all within 0.1. Got the incedence meter and best i can tell the incedence is just fine. I put 1 washer in to give it up thrust and seemed to help. Going to put 1 more in and see how it does. It finally harried and hovered so its getting better but it still has up elevator trimmed in. Atleast it flew much better.
My Feedback: (41)
That's great. I assume you're doing this but make sure to re-trim the elevators during flight after you add washers. Then do your thrust test by flying straight and level at high throttle. Then chop throttle. It should maintain altitude for a while (and not gain altitude). Removing the engine up thrust lets you remove some of the up elevator trim you had in there. Sounds like you're getting there.
Nice looking plane.........just need to scoot that pilot back a touch there!!!!!!
ORIGINAL: fireblade5437
Any ideas?
Any ideas?
My Feedback: (10)
OH
Can anyone please save me some time in reading this thead ad let me know where everyone is setting thier CG at? Thnaks in advance.
My Feedback: (41)
Depends on your flying taste really. At the front of the range for IMAC, near the middle for 3D stuff. I think mine is at 7 1/4". The range is 6 3/4" to 7 1/2" at wing root.
http://www.extremeflightrc.com/manua...ManualRev2.pdf
My Feedback: (10)
OH
Thanks Joe I did already download the manual. The problem I am having is with a Dl50 with the stock muffler and standoffs And adding another A123 batter that is not even hooked up I am still way to tail heavy. I am trying to think of was to add usefull weight.
My Feedback: (41)
I have that same exact engine setup. My ignition battery is next to the tank. The rx batt is behind the wing tube. No pilot or dash. Perfect balance.
Do you have the louver on the cowling? Also what prop and spinner? I can't imagine what would make yours so tail heavy when your setup is just like mine.
My Feedback: (10)
OH
Thats what i could not figure out. Before I started to build this I skimmed through this thread and saw you setup and thought well this will be easy. I am running a xoar 22x8 prop. I am looking to order a new spinner and a new cowl for this plane as i got this plane used and the cowl has been really cut up.
I fly with a DLE 55 with stock muffler and Vess 23 B. My 4" Tru Turn spinner weighs approximately 4 oz. with the lightened back plate. I also reinforced the polystyrene cowl baffle with fiberglass, after the first one developed a crack. I also reinforced the perimeter of any cowl cut outs and added epoxy in the engine box corners. My 2 Life 2100 Mah batteries are located behind fuse rib located behind the wing bolts. People I know, who fly without the spinner, baffle, etc. appear to have the same issue as yourself. My CG is around 7". It was very nose heavy at 7 1/2.
My Feedback: (41)
Are you using a spinner when you're checking the CG? That affects the balance a lot. My spinner is about 3.5 ounces. It's CF. Also my louver plate added a couple of ounces with the glass I used to reinforce it. What is your CG right now? I think 7.5" is the aft end of the range.
My Feedback: (10)
OH
You guys hit it right on the nose. I was trying to get by without using a spinner. I never really had a plane that could not balance without a spinner and I was unsure if the spinner would be enough. I was also debating on running a ks86 cannister but it looks like that may move the CT even more aft. Right now it is still tail heavy measuring at 7 1/2 inches.
My Feedback: (20)
VA
Any ideas?
Any ideas?
Biela 2 bladed CF props are pretty quite.
