Extreme Flight 88" Yak - Build and Fly
#1626
My Feedback: (31)
NC
RE: Extreme Flight 88" Yak - Build and Fly
Maudib
very nice i will get with u to get somemore graphics to put the word out there i love that extreme flight one and the penzoil ones
#1631
My Feedback: (13)
ON, CANADA
rdb127,
Are you happy with the performance of the G62 lite along with the ESComposite pipe? Which pipe length did you go with [ baffle distance inside the pipe] plus did you modify a DA return to center header to fit? Thanks for any info that you can share as I,m going to Toledo and plan on picking up the necessary parts there.
thx Dave
thx Dave
#1632
My Feedback: (42)
DLEVETT
By the end of the day today I have 6 flight hours, just started into my third galllon. After having the pipe slip loose twice I am using a different material, got that problem fixed... got the needles all out of wack- then set them right (always learing) then fixed the endpoints of the throttle and today was a real pleasure to fly.
I now have the G-62 set at 7500 rpm and the transition through the middle is silky smooth. Response is great now and I wonder if I will be spoiled when I go back to my DA-50 Extra. I have tried 9 ways to heaven to get the burbble out of the bottom end of that.... nother story.
I believe that even when set up correctly the G-62 will shake the airframe more than many of the 50 cc's. The wood airframe after 6 hours has held up perfectly. I did have cracked a canopy lip and the intake of the engine (caught it just starting-will be inspecting the cowl regularly now) but I blame it on having the G-62 so out of wack that it would be my own fault.
Having said that, I still enjoy the opportunity to run the G-62 on the pipe. The header is a modified 25 mm DA flex header (I think it measures 11 inches) the pipe has the baffle set at 17.5. The engine has a bellow when screaming the upline. The Vess 23A just keeps grabing air- that is a neat prop!!
For you guys wanting the SD cf gear I believe that they certainly will have their limit. I dropped one in today and felt I had to inspect. There are no visible cracks although I expected that there would be. It is just that the gear did not give as much of a bounce-so they were very stiff- how many harrier landing would they take before something has gotta give somewhere. JMO
http://www.youtube.com/watch?v=jps3cDMJnm4
#1633
My Feedback: (31)
NC
all the plumber just let and for 98.00 i am back in business along with that the UPS man has arrived with my new power plant a converted BME 100 to a 111 using the BME 115 for most of the build. Off to the garage i go
#1634
My Feedback: (29)
AZ
that motor sounds very nice....excellent wall btw...my wife may let me get this one, i told her thats good because my name is on the list already
#1635
My Feedback: (63)
ORIGINAL: krayzc-RCU
#1638
My Feedback: (10)
IL
RdB....that is the baddest G-62 I have heard....has Ralph seen the video???
Makes me wonder if I SHOULD put the DA stickers I got from Maudib today, on my Yak.
Cant wait to see it with a 24 x 8 MenzS and Synthetic oil. It really sings.
#1640
My Feedback: (42)
Thanks Dave. My smile muscles hurt from a long day of smiling It is a great plane. I was even thinking of moving out my unbuilt 33% AM Yak if I could get close to breaking even. Fat chance, I see somewhere that Chief Aircraft is selling them for $599-629 depending on color and free shipping!!
I am thinking the 3W80XI on full tuned pipe when Chris releases the 107 inch (was it Extra or Yak).[X(] . Might go something like, 107 inches, 25 lbs dry 54 lbs of thrust, well a guy can dream can't he?
RDB
RDB
#1641
My Feedback: (42)
ORIGINAL: Bosshossv8
Oh yeah, a big thanks to flyinrazrback who helped me sort through my pipe problems. The guy is sharp.
RDB
#1643
My Feedback: (42)
This one says breaking in the G-62 but I think I am more breaking the the beast. Complete with indecisive harrier landing.
http://www.youtube.com/watch?v=jbQcD9cYRDQ
#1645
My Feedback: (63)
ORIGINAL: rdb127
The wind was blowing what? 20+...haha.. You could totally tell... Nice Video..
#1646
My Feedback: (16)
CA
ORIGINAL: GalenB
The "91K" is Cyrillic script (Russian) for Yak...
#1648
My Feedback: (42)
ORIGINAL: Mokken
ORIGINAL: rdb127
Thanks, the wind only blew 20 when I wanted to get close to the ground!
#1650
My Feedback: (63)
ORIGINAL: vfalcon7
Hello, Is anyone running the ES pipe with the B60 with the baffle at 18.5? That is what he sent me. Is this right.
