3W tanks
My Feedback: (16)
CA
RE: 3W tanks
ORIGINAL: RobT
Thanks Boatnik,
Did you do anything special to keep the cap from unscrewing?
How did you mount the round tank?
Thanks again,
Rob
Thanks Boatnik,
Thanks again,
Rob
Just make a squar mount, cut a hole in it the same dia. as tank, split this in half and there you have it.
My Feedback: (56)
RE: 3W tanks
After the first couple tanks I would check and tighten if needed. I never
had one loosen after that. You can make a couple tick marks with a Sharpie
on the tank and cap to have a visual if loosening is happening.
