37.5 or 40% Yak
MB, CANADA
37.5 or 40% Yak
I've just bought a 3W 212 B4 QS engine and would like some opinions on which TOC Extreme Yak I should put it in. I was going to go with the 170CS in a 37.5% but the 4 cyl sounds so sweet but 3 lbs more. Should I go with the 121" or the 129" wing span? Do these planes balance ok with a 12 lb engine? Does anyone have any experience with 212 B4?
Any info appreciated.
My Feedback: (16)
TX
RE: 37.5 or 40% Yak
It will not balance on a 37.5%, period... It will be nose heavy on a new version 40% SD Yak... 12 lbs is a lot of nose weight to counter-balance... My newer version 40% SD Yak balances perfectly with a 8.5 lb engine... AUW is 45 lbs...
That's if you can find a 40% version... I've been told that they are technically out of production, but SD will build them if the factory gets an order for 10 or more from a dealer... Chief or Troybuilt may still have some in stock...
Hope this helps...
Hope this helps...
MB, CANADA
RE: 37.5 or 40% Yak
ORIGINAL: Torqued-Up
Hope this helps...
Hope this helps...
RE: 37.5 or 40% Yak
If I were you, I would go with the Aerotech 40% YAK 54.
John can give you a very good suport and you can order it as a KIT, ARC or ARF.
Go to www.aerotech-rcmodels.com
Take care
Marcelo Assis
Take care
Marcelo Assis
My Feedback: (16)
TX
RE: 37.5 or 40% Yak
ORIGINAL: Biglen
Thanks for the info, where are your batteries etc mounted? Can I shift stuff back to get it closer to balancing? Also the 212 is 3.58" longer than a 3W 157. What is the distance from the firewall to the front of the cowl? Can I shorten the firewall to recess the engine more?
Hope this helps...
Hope this helps...
I have all my batteries mounted as far forward as possible... You can easily move the batteries back 3 feet to further help CG... I'm using a Seiko servo on rudder and it's mounted right behind the pipe tunnel... Again, moving this servo as far back as you can gets your CG back even more...
I think you could get it to balance... You will just have to be creative... It should be awesome...
