inside a canister
My Feedback: (16)
BC, CANADA
RE: inside a canister
all sorts of pipes and tubes and crimps and sections etc etc. I have one with the outer skin removed, thanks to wing failure that caused a crash and I lost a plane and a set of canisters. I will take some pictures and post them so you can see what the inside of a KS canister looks like.
My Feedback: (27)
NE
Thank you very much guy's, That doesn't look too hard, I have the material's and the guys at work can weld it. I will give it a try and maybe save $ 140. I'll still have to buy the header & coupler. Does any one know what header I'll need for the SD models 33% Yak & the DA 85 ? I DO NOT want any flex header if I can avoid it. I'll build the canister around the header if I have to, but I would like to get as close to a drop in header as possible. Thanks for the help.
My Feedback: (25)
Can You Give The Diameter And Length Of The Cannister That Is Pictured ? I Have Been Wanting To See What Was On The Inside Also So I Can Make My Own. Have Made Many Custom Mufflers For Myself And Others And Don't Believe These Will Be Any Problem. The Pictures Really Helped.
IN
ORIGINAL: RVBlack
What does it look like inside a typical canister ?
Sorry guy's, I resisted for a couple of day's but could'nt take it any more!!
Very interesting though as I just installed my first set of cans.
Marc 540[8D]
My Feedback: (62)
NJ
I have a set of Pefa cans I'll let go for $50 for the pair.
I used them on my 3W 150.
One has something loose inside, and I'm not a welder.
Pictures available upon request.
Bob
Bob
My Feedback: (62)
NJ
They measure 16.5" long including mounting flange, 15" long not including the flange, and 2.75" diameter.
It says Pefa made for 3W on the can.
If you move your cursor over the picture, you might hear the rattle [X(]
