Extreme Flight 110" 100cc Yak 54 Build!
#752
My Feedback: (29)
AZ
RE: Extreme Flight 110" 100cc Yak 54 Build!
ORIGINAL: xtraflyr
This is alot of money to me too. Im pretty sure Im going for the original color too. I have the 74" in the white/red and the 88"in the same color. Im pretty sure Im getting rid of the 74". Possible for the 78" Extra Chris has coming out with..
I have to see what Im stuffing the 110" with. Think Im goin to switch over to 2.4 on my 9303 with the adapters for it. Or get the JR 12 ch.(Yea right)!!
Cya,
Frank
ORIGINAL: diamondave
, once my mind is set on something i think about it alot, ive been thinking of this thing since it came out, been begging, borrowing, next is steeling, haha... yes we all agree now i will get the 100, just what color? haha no that is made up already, the blue, i have the black/yellow 88 so i want the blue one of this size, maybe the red 74" someday, my minds pretty much made up on the rest of componants and how i will outfit it, believe it or not
ORIGINAL: xtraflyr
So Dave, You think the 100 will be enough power for this plane!!??Just Kidding!!
Now back to our program..HAHAHA!!!
Im goin the way of the DA 85 on a KS Tuned Pipe..I think I have a big bonus coming from work this October..WOOHOO!!!!
Cya,
Frank
Cya,
Frank
Cya,
Frank
#753
My Feedback: (29)
AZ
do you guys think 5985's are enough for ele and ail? i have them on my 33% and havent noticed any issues, i think tbm says they used them on a 40% ele and had no problems, i just love the speed and percision, plus the $$ difference to get 5955's times 6(ele&ail) would be enough to get my battery packs, i understand the rudder needing alot of torque during knife edges and such, but my thinking is the ele arent at alot of throw during high speed moves, the only time i use alot of ele is harriers, elevators, spins, things like that, not a whole lot of wind speed at that time, just wondering what your guys thoughts are, i will get 5955's if you all say so, id like to hear what could cause the 85's to not be enough though just for curiosity
#755
CA
You should be fine as far as torque. The real advantage to the 5955's on the elevators is the titanium gears. The 5955's will last for as long as the plane. The 5985's will wear after awhile.
#756
My Feedback: (74)
TN
So what you try to say is 5955 last long time.....
One 8711 on the rudder will do fine. That way you could cut out the price of one servo.
ORIGINAL: dbcaster
#757
My Feedback: (29)
AZ
yeh i thought i read that about 1 8711 for the rudder, thats on my 33% also, i like that set up, what about the wings? since there is 2 each they should be okay on that right?, ....plus i wonder how long it will actually take to wear out the gears, i do have a 5955 on my rudder on the 88yak and i like it, but i love the 5985s on the ele and ailerons on that plane too, i cant really see the difference in speed, supposed to be .13 and .15 for the 5955, the only time i noticed speed was when i originaly had 5645's on the ailerons and 5985's on the elevator, the ailerons were like in slow motion, it was rediculous, i suppose i could use 5955 on ele and 5985's on ailerons and still have a $$ savings for a battery or 2, see what anybody else has to say, thanks
#759
NJ
Since they use 2 servos per aileron you can get away with something a little cheaper then the 5955s,correct? Actually by the time Im ready,there wont be anymore 5955s. Have to step up to the 7955s?
Cya,
Frank
Cya,
Frank
#760
My Feedback: (29)
AZ
i havent looked into the 5945's, they arent like the old 5645's are they? i am leaning towards the 5985's now since we all seem to think there is plenty of torque, i am tossed about the ele at the moment, but kinda thinking 85's on there also, and the 1 8711 for the rudder
#761
My Feedback: (42)
Dave I recommend you stay away from any used 5945's. The weak spot on the 45's is the servo pot. When they updated the 5945's to the 5985 they supposedly addressed that issue. We have worn out 3 of th 45's on 50cc yaks (aileron) at the club and they caused minor flutter at low power and mid to low airspeed. Even if you get the 45's new you might expect them to eventually become worn. Beyond that they are an awesome strong and fast servo and I am still using the onces already on planes with a watchful eye.
R
R
#762
My Feedback: (29)
AZ
k, thanks, i think i will stick with the 85's then, so far they have been great to me on my 88yak(ele and recently ail) and the ele of my sdyak, i had a 5955 give me centering issues so far but not the 85's, sounds like a plan, or should i ask a few more times, haha gotcha guys, ne-ner-ne-ner
#763
TX
#764
TX
DD, do you have a Hitec digital servo programmer? If you use one, you won't have a centering problem with the hitec servos.
#765
My Feedback: (61)
NJ
ORIGINAL: torqmeister
I think you need the power of the 5955 on the elevator. Don't go with the 5945 there. My .o2.
#766
My Feedback: (29)
AZ
i was thinking of the 5985's not the 5945's, i havent looked up the specs, are the 85's enough on the elevator? or should i get 55's for the ele and 85's for the ailerons
i dont have a programmer my buddy lent one to me to do my sd yak, was the 1st time with multiple ail, i was thinking of buying one myself this time, but he will lend it again if i want to be cheap still.
i had a problem with my 5955 on my rudder on my 88yak, not even a year old and it started "jiggling" at center, even after a few flights so i dont think it was high voltage, i could just touch it and it would stop, after some sugestions on that yak thread, i simply moved my trim 2 clicks(4 on the radio cause i lowered it from 4 to 2, if that makes sense), anyway it went away, i can snap it back, play with it all i want and it wont do it now, and it wasnt even enough movement for me to redo my wires, barley moved the rudder with the trim, so i think its good to go, someone said something about the pot? or pod? i dont know, i guess eventually i will need to do something with it like send it in, but it works just fine now that its moved, anyway i dont have any bad feelings towards the 55's, i like them and the 85's
so whats the final verdict for the ele? 5955's or 5985's? sounds like 85's on the wings
#767
I think you could get away with 5985s on the tail, but personally I would stick with the 5955s. They are big control surfaces and even with a smooth engine there is still quite a lot of vibration at that end of the plane, so I think the Titanium gears will last you longer. Not sure what the price difference is probably $20 per servo, but worth the extra IMHO. Not sure 5985/5955s will be available so go for the 7985/7955s.
#768
My Feedback: (29)
AZ
thanks, i was wondering about that 7500 thing now, guess thats the way to go, updated, i will get 55's for the ele, and the 85's for the ailerons, 8711 for the rudder, we are getting a game plan now
#769
My Feedback: (29)
AZ
i was curious about battery for ignition, on my 60 i have a 1650 6v metlhydryd, on my 80 i got a 2000mah only cause i got some from tower and hydomax doesnt make a 1650 anymore, my buddy says thats overkill, but it doenst way that much more than a 1650, so anyway, this will be my 1st twin, does it use the same amount of battery?, seems i am getting around 200-300 mah per flight on both my single engines, that sound about right? will a twin be any different?
#770
My Feedback: (74)
TN
Just a quick video of mine.
http://www.flyinggiants.com/gallery/...hp?photo=50160
Just enter FlyingG1ants.Com in the **** you know what I mean.
#771
TX
#772
My Feedback: (74)
TN
or try this....
http://www.youtube.com/watch?v=a4UFKY7gh8g
#773
NJ
Hey, looks good. I'm just finishing up the one I'll be flying at the RDRC Fly For Tots. It basically looks just like the one I lost a couple months back, same setup also. Can't wait to get it in the air.
Lee
Lee
#774
My Feedback: (29)
AZ
I have a Kroma100 twin. Am using the A 123 racing battery, 6.6V. Am using 140 mah/flight.
#775
My Feedback: (74)
TN
Thanks Lee. Still trying to get the throttle curve dialed in. Getting closer though.
I just got to get a little braver with this plane. Something about a big plane 10 feet from the ground still seems to rattle me.
