BME Aircraft vs. BME Engine props?
What is the difference between these two props. I ordered the BME Aircraft prop thinking it was the prop that is marked with BME Engines but soon found they are different.
Is either better? |
RE: BME Aircraft vs. BME Engine props?
BME aircraft and BME engines are two different animals. BME engine is in Texas somewhere and BME aircraft is in Canada. I have the BME aircraft prop and it looks a lot like the Menz, MSC, or NX props...the wood grain actually looks better and the tips are painted white. I got it because I couldn't find any other props anywhere else and had to have something fast...glad I came across it!
It looks to me that the BME Engines props are of one solid piece and the BME Aircraft is a laminated layered prop.
Is this the correct description of a laminated prop? Is there any advantage or disadvantage? |
the advantage is it is stiffer meaning less twist. no disadvantage.
YNC,
The laminated is stiffer? Thanks |
Yes thats right.
From what I haev understood, laminated propellers are stiffer and quieter. They tend to come apart quicker when there is minimum damage to them.
Are the BME Aircraft props true to size. Is a 22" prop 22" or 21.5" long like some of the foreign models. I know BME Engine props are true size.
Thanks, ML |
BME Aircraft and BME Engine props are made in the same factory, even 3W, NX or MSC are the same. Only the design and materials are different. . They're all true size. But laminated material does has its advantage
Aeromax |
| All times are GMT -8. The time now is 08:52 PM. |
