servos foe a 33% extra
FL
i have a new 33% extra and would like advise on servo selection.looking at ds8611a, is that a overkill, can i use one on each alerons, plane will have a zdz 80, should be around 22lbs,what do you guys think.
RE: servos foe a 33% extra
Whos 33% Plane is it? The 8611's are a good choice, or the 7955 Hiteck's. Especially on the rudder. I have a TOC 33% extra 260 and Yak, they require two servos on each aileron. Im running 7955 all around on the Yak, and the extra 260 I tried 7985's on the ailerons. The 7985's are a little less rated than the 7955's but seem to be working just fine, both for 3D and IMAC
