Pull-pull accessory; anyone recognize?
My Feedback: (19)
IA
Several years ago when I lived in California, I purchased a pull-pull accessory for my giant scale plane (see pic attached). Isold the plane, and would like to buy another one, but can't remember who makes it or where I bought it. Does anyone recognize this part? Thanks, Jim
My Feedback: (19)
Not exactly the same as your picture, but go here for something very similar. Look under rudder trays.
http://www.whiteroseeng.com/
CA
How would this be used in an airplane?
Unless the connection on the control surface is also a wheel the cable would tighten or loosen depenging if the horn is in front of or behind the hinge line. A loose cable on a pully would invite it coming out of the groove. By using regular arms and horns you can set it up to stay tight all the time or give a little slack when off center.
My Feedback: (158)
Hanger 9 makes those wheels,
I can't rememebr who made the shaft support,,,, you could make you own supports up pretty easy
here are a couple
http://www.horizonhobby.com/Products...ProdID=HAN3512
http://www.horizonhobby.com/Products...ProdID=PRB4013
here are a couple
Are you looking for the wheel or the axis support? I've seen the pull-pull tiller setup with the axis support but, naturally, I cant find it. Doesnt seem that hard to fabicate using off the shelf parts.
Edwin
Edwin
JR made the output support. I haven't seen one for quite a while, not sure if they still make it. I can't find it on Horizon's web site.
Bob
Bob
My Feedback: (19)
ORIGINAL: Balsawings
Bob
Bob
My Feedback: (19)
IA
Thanks for the help everyone!
I used it for pull-pull cables on my rudder, and then there's a mounting hole for a 4-40 stud to attach a ball-link and push-rod for tail wheel control. Works great. You're right, they are the JR pulley discs from Horizon Hobby. I was looking for the support . But I agree, if I use a high quality ball bearing servo and I probably won't need the additional support.
Very interesting products from White Rose Engineering.... always looking for new stuff and new ideas!
Jim
Jim
