Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
ESM Beechcraft Bonanza V35 V-Tail
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 01-31-2017, 04:39 PM
Walther
May I ask where you purchased it from?
Old 02-01-2017, 01:02 PM
Gunner1068
My Feedback: (7)
Gunner1068's Avatar
Sure, I found this plane on EBAY. I entered ESM Bonanza, expecting to find the usual 469.00 price tag from AFPROS, but got sticker shock (good shock) when the plane was only 299.00
Old 02-07-2017, 08:47 AM
FlyerInOKC
FlyerInOKC's Avatar
Hi Gunner I can see why you snapped it up at $299 its a nice plane. Thanks for mentioning to me over on the Hostetler thread. Would you please shoot me a picture of your nose retract mount? I think I got all the dots connected on the Bud Caddell design I purchased. I pulled a copy of the TF Bonanza manual and the pictures helped. I was making some wrong assumptions and I think the ESM design will prove me out. Will you be posting a video of the maiden?
Mike
Old 04-26-2017, 06:13 PM
Gunner1068
My Feedback: (7)
Gunner1068's Avatar
Default ESM Bonanza
Finally have my new Bonanza on her feet. This plane has taken longer than expected to assemble. I'll try to post a vid of the maiden.
Name:	ESM Bonanza adjusted.jpg
Old 04-26-2017, 06:15 PM
Gunner1068
My Feedback: (7)
Gunner1068's Avatar
FlyerInOKC, do you still want pics of my nose gear retract mount. Sorry for the absence, I've been away for work since Feb!
Robert
Old 04-26-2017, 08:27 PM
  #31
Twin_Flyer
looks great Gunner!!
Old 04-27-2017, 05:11 AM
  #32
FlyerInOKC
FlyerInOKC's Avatar
Robert
Yes I would thank you Gunner. That is one gorgeous hunk of airplane you got there!
Old 04-27-2017, 05:56 AM
  #33
Gunner1068
My Feedback: (7)
Gunner1068's Avatar
Thanks...I think the ARF version looks as good as the TF kit, certainly less building! This would be a great candidate for bashing this plane into a super scale Bonanza. With some mods a person could definitely turn this plane into a masterpiece.
FlyerInOKC, I'll shoot some pics of the nose gear mount later today.
Old 04-27-2017, 06:05 AM
  #34
FlyerInOKC
FlyerInOKC's Avatar
I have been meaning to ask is their much difference other than tail between the ESM A36 and the T35 "V" tail? What wheels are you using?
Old 04-27-2017, 05:49 PM
  #35
Gunner1068
My Feedback: (7)
Gunner1068's Avatar
OKC Flyer...have some pics for you:
First pic I have is from the TF Bonanza nose gear mount. As you can see from the pics: the design is pretty basic: a couple plywood pieces coming out from the firewall with come wood skirts added for structural strength.Click image for larger version
Name:	TF Bonanza nose gear mount.jpg
Second I have a pic of the nose gear mount from my (nearly) complete ESM Bonanza:Click image for larger version
Name:	ESM Bonanza nose gear mount.jpg
Here you can see I'm going to use some basic foam wheels I had laying around the shop for my first few flights. I like to use foam wheels on a new plane until I can determine sink rates on landing with and w/o flaps.Click image for larger version
Name:	ESM Bonanza wheels 1.jpg
Here's another pic of the ESM Bonanza A36 wheels, this shot shows the gear installation pretty good:Click image for larger version
Name:	ESM Bonanza wheels 2.jpg
Old 04-27-2017, 06:01 PM
  #36
Gunner1068
My Feedback: (7)
Gunner1068's Avatar
As far as the difference between the two airplanes, other than look, and from what I've heard from other pilots, there isn't much difference. Both planes handle well in the air. Some people like the look of the V tail over a conventional look of the A 36. I'm an A 36 guy all the way. Something about the look of the A 36 just screams class and style in a great design. If I were to win the lottery I'd spend my time designing low wing civilian models from 48 inch ws to 100 and market an entire line of civilian ARF and kit planes. Then I could die a happy man!!!
Old 04-28-2017, 06:32 AM
  #37
FlyerInOKC
FlyerInOKC's Avatar
The V tail had the nickname "Doctor Killer" because it was a handful when attempting to fly on instruments in heavy clouds by VFR pilots. The problem really wasn't the airplane but the loose nut holding the yoke. The projected performance improvement due to the weight savings of the "V" tail never really materialized so they went to a conventional tail.
Thanks for the pictures Gunner! I have to modify the nose gear mount on my Caddell A 36 and I wanted more than one example to go by. It was originally designed for Rohm retracts mounted at a weird angle I am using a NIB Robart TF Bonanza set.
Old 04-28-2017, 08:51 AM
  #38
Gunner1068
My Feedback: (7)
Gunner1068's Avatar
One thing you may want to consider is the nose gear point of attachment angle axis. You can see in yellow, the angle the NG rests when fully extended. I believe this allows for full deflection of the oleo strut and doesn't impart loads on the mounting plate. Red line is where I see a lot of models mounting their NG struts. I realize sometimes the plans call for mounting this way but I'd always look to a different mounting option if the original mounting looks flimsy.
Old 05-21-2017, 05:48 AM
  #39
Gunner1068
My Feedback: (7)
Gunner1068's Avatar
Anyone know where I can get scale wheels and tires for my ESM Bonanza? I need rims that will fit a 5.5 mm axle shaft on top flite Bonanza retracts.
Looking for 3.5 inch mains and 2.75 inch nose wheel.
Robert
Old 10-04-2017, 05:27 PM
  #40
clarkj
My Feedback: (26)
I have one of these a guy gave me with a saito 120 mounted on its side with the engine sticking out. Looks horrible for a scale plane. How are you guys mounting gas engines in them? Pics please
Old 10-05-2017, 06:52 AM
  #41
FlyerInOKC
FlyerInOKC's Avatar
My A36 will have a Glow engine mounted on it's side (Inverted is not an option due to the nose gear.) with a J'TEC or Top Flite muffler. Bud Caddell had a Webra -61 on the prototype and he had plenty of power even running it a little rich. I will probably go with a modern .75 or .90 engine. Here is a picture of Bud's prototype.
Name:	Caddell A36 Webra 61.jpg
Old 06-27-2018, 02:31 AM
  #42
davidmc36
davidmc36's Avatar
I think the way to put big CC gas motor is with extension pipe and exhaust can behind the firewall.
