Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
PIPER TOMAHAWK -Messer Plans
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 03-06-2011, 12:08 PM
jperkinstrades
My Feedback: (25)
Default PIPER TOMAHAWK -Messer Plans
I have decided to start a blog on the plan build of my Piper Tomahawk. Plans were drawn by the late great Jim Messer. Plans and cowl were supplied by Dave Reid of Reid's Quality Model Products. I also purchased a out of production book based on Messer's kit of this plane back when he produced a kit. The book is titled: "Building and Flying Giant Scale Radio Control Aircraft" by Bob Beckman. I start out making hard templates of all the fuse formers, wing ribs, gussets, etc. I use a product called SEE TEMP. Available thru Dynamic Balsa and Hobby Supply. www.dbalsa.com. Ths product is a transparent red plastic that is easily scored with a knife and thne you bend it one and it snaps free leaving you with a hard template to trace parts.
ID:	1574260   Click image for larger version
ID:	1574261   Click image for larger version
ID:	1574262   Click image for larger version
ID:	1574263   Click image for larger version
Old 03-06-2011, 12:31 PM
jperkinstrades
My Feedback: (25)
Default RE: PIPER TOMAHAWK -Messer Plans
I am a little behind on the posts so I will try to get caught up to the building point I am at today. I put together a complete materials list which was all oredered through www.balsausa.com I finished cutting all my hard templates and have started cutting fuse formers. The fuse construction starts with a jig that is shown on the plan and in the book. The jig makes the fuse very straight and true.
ID:	1574276   Click image for larger version
Old 03-06-2011, 12:38 PM
jperkinstrades
My Feedback: (25)
More fuse pictures
ID:	1574278   Click image for larger version
ID:	1574279   Click image for larger version
Old 03-06-2011, 01:04 PM
huck1199
huck1199's Avatar
Very nice. How do you keep the jig blocks from moving? Is the central plank glued to the blocks?
Old 03-06-2011, 01:38 PM
dreid
My Feedback: (13)
It appears you have done a nice job cutting out your parts and gluing up what you have. I will watch your progress.
Old 03-06-2011, 02:14 PM
jperkinstrades
My Feedback: (25)
huck199 , I ran a screw thru the central plank into my 6" upright blocks. The blocks are a piece of 3"x3" drop off from a handrail post I had leftover from work.
Old 03-06-2011, 02:51 PM
jperkinstrades
My Feedback: (25)
I was able to make some progress this weekend on the vertical stab/rudder and the horizontal stab/elevator. The vertical stab and rudder are based on a piece of 1/8" plywood that all the ribs are glued to. I opted for some lightning holes in the ply to try and cut down some weight. The main wing is 100" and is one piece. I think that is a big wing to have to haul around so i plan on making it 3 pieces . I will consist of a center section with tubes that stays bolted to the plane and two outer wings that will remove just past the main landing gear. I think leaving the center section with the plane and having the main landing gear still attached to the plane will make for safer and easier transportation of the fuse. I have ordered some wing tube sockets from TNT landing gear and the aluminum tubes from Aircraft Spruce and Specialties, there tubing is cheaper and can be bought in any length you want. As soon as the pieces arrive I will start on the wing.
ID:	1574349   Click image for larger version
ID:	1574350   Click image for larger version
ID:	1574351   Click image for larger version
ID:	1574352   Click image for larger version
ID:	1574353   Click image for larger version
ID:	1574354   Click image for larger version
ID:	1574355   Click image for larger version
Old 03-06-2011, 03:02 PM
jperkinstrades
My Feedback: (25)
Some pictures of the Horizontal/elevator. Still plenty of sanding and sheeting to go .
ID:	1574358   Click image for larger version
ID:	1574359   Click image for larger version
ID:	1574360   Click image for larger version
ID:	1574361   Click image for larger version
ID:	1574362   Click image for larger version
Old 03-06-2011, 06:08 PM
Taildragger726
Taildragger726's Avatar
Looks stronger than a real "Tramahawk" !
Keep up the good work.
Old 03-06-2011, 08:25 PM
rcfan450
Very nice! I'll keep my eye on your post... and I'll be there for the maiden if you do it in Heber.
Old 03-07-2011, 02:37 AM
TomCrump
TomCrump's Avatar
I have access to an original Messer Tomahawk kit. I plan to follow your progress with interest.
Old 03-07-2011, 06:36 AM
jperkinstrades
My Feedback: (25)
rcfan450, I could always use a great video of the maiden. I'll keep yoou posted .
Old 03-07-2011, 05:17 PM
tailskid
My Feedback: (34)
tailskid's Avatar
I spent a few hours in one of these right after Piper released them. It looks like you are doing a great job - keep up the good work. I did pick up an AirSail kit a while back - I'm tempted to open it up
Old 03-08-2011, 08:31 PM
jperkinstrades
My Feedback: (25)
Today I was able to sand, shape, and sheet the horizontal/elevator. I was also able to sand and shape the wing tip blocks. On the real Tomahawk, the tips of the horizontal are attached to the elevator, but Messer's drawings show them fixed to the horizontal stabilizer. I felt that the dynamic balance provided by the moving tips is as useful on the model as on the full scale aircraft, so I made some modifications so that mine are scale. I cut my stab parts to the elevator lengths shown on the plan, and I cut the elevator parts to the stab lengths shown on the plan, a pretty easy fix. The tip blocks were glued to the elevator.
ID:	1575778   Click image for larger version
ID:	1575779   Click image for larger version
Old 03-09-2011, 03:28 AM
Tony Hallo
Nice, do you plan to mass balance as well? I friend has the Great Planes version, the servo is mounted the rudder.
Old 03-09-2011, 03:56 PM
jperkinstrades
My Feedback: (25)
Tony, I do plan to mass balance . I am in the process of working out the details for mounting the servo in the tail with a short linkage. The plan shows the servo in the front of the plane with cables and bellcranks to get to the top of the tail, to much work and to much to go wrong. I will post some pictures of how I did it when I have it completed.
Old 03-10-2011, 03:21 AM
Tony Hallo
His is a glass fuselage, made the rudder post removable for servo access. When he bought the plane, push rods and bell cranks were installed, way too much slop.
Old 03-17-2011, 10:46 AM
jayshelby
Nice build! I have some plans for you when your done. 140" katana sounds fun right?
Old 03-18-2011, 07:09 AM
keyserman
My Feedback: (59)
It looks good Jake. Should be done for this summer, right? I look forward to your maiden. What are you planning as a powerplant? Makes me want to build another big one.
Old 04-12-2011, 08:47 PM
jperkinstrades
My Feedback: (25)
Has been a little while since I have posted. A few pictures of the wing building. "The main wing is 100" and is one piece. I think that is a big wing to have to haul around so I made it in 3 pieces . It consisst of a center section with tubes that stays bolted to the plane and two outer wings that will remove just past the main landing gear. I think leaving the center section with the plane and having the main landing gear still attached to the plane will make for safer and easier transportation of the fuse. I ordered wing tube sockets from TNT landing gear and the luminum tubes from Aircraft Spruce and Specialties, there tubing is cheaper and can be bought in any length you want". I also made servo mounts in the wing at each aileron. The plan shows a single servo in the center section with rods and bellcranks .
ID:	1593254   Click image for larger version
ID:	1593255   Click image for larger version
ID:	1593256   Click image for larger version
ID:	1593257   Click image for larger version
ID:	1593258   Click image for larger version
ID:	1593259   Click image for larger version
ID:	1593260   Click image for larger version
ID:	1593262   Click image for larger version
ID:	1593263   Click image for larger version
ID:	1593264   Click image for larger version
Old 04-12-2011, 09:00 PM
jperkinstrades
My Feedback: (25)
A couple More
ID:	1593274   Click image for larger version
ID:	1593275   Click image for larger version
Old 04-13-2011, 05:00 PM
rcfan450
Looks good man!
Old 01-15-2012, 06:06 AM
TomCrump
TomCrump's Avatar
Was this model completed ?
Old 01-15-2012, 01:37 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Boy I sure hope so...I'd love to see the finished product.
Old 01-21-2012, 08:04 PM
SteveD-RCU
SteveD-RCU's Avatar
Ya would be nice to see..I'm thinking of doing this one...someday..I would add flaps like the full scale.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
