Reed Weeks Solution Plan
My Feedback: (9)
If any one has a set of Miles Reed, Weeks Solution Plans I would like to purchase them, or a copy if possible.
I have been trying to find the 70" (actual 69.5") Weeks Solution Plan with no luck. evidentlyDave Dresseker is not around or just not selling the plans , as I get the following using this address
Dave Desseker- The following addresses had permanent fatal errors -
<[email protected]>
(reason: 554 5.7.1 <[email protected]>: Recipient address rejected: Access denied)
and as someone sudgested Precision cut kits does not handle them in fact they refered me to the above address?
Thanks Dave
</p>
check with Ken baker at Ridge Machine, hes the maker of D&B enines. He located in Warren Ohio. you can google search D&B engines. He was good friends with Miles and can Im sure steer you in the right direction
