ECOMRC first look out of the box!
Hi everyone, I'd like to share a couple pictures of the ECOMRC CESSNA 195 107" Wingspan right out of the box!
First impressions:
-extremely light weight
-wood construction in the fuselage looks great
-all pieces dry fit together perfectly!
We will be taking some more pictures and video tomorrow so stay tuned!
First impressions:
RE: ECOMRC first look out of the box!
Here's are a couple pics of the inside of the Cessna fuselage and also a couple of the ECOMRC Piper PA-25 97" Wingspan!
Jeff wouldn't shut up about how the other Cessna picture didn't show how big this plane really is so check out this one!
ORIGINAL: aussiesteve
Is that a Butt joint or a doubler near the bottom of the former in the 3rd pic on post 2 ?
Nice looking plane
Nice looking plane
Here are some more pictures and some video of the Wilga, let us know what your thoughts are!
Complete set of the pictures can be found here: [link=http://www.troybuiltmodels.com/items/ECOMWILGA-89AAF.html#4]http://www.troybuiltmodels.com/items/ECOMWILGA-89AAF.html#4[/link]
[youtube]http://www.youtube.com/watch?v=lEtImfEKj6s[/youtube]
I just bought ECOM RC Wilga and have started a build thread ... [link=http://www.rcpak.com/index.php/forum/12-arf-a-rtf/34047-wilga-89q-from-ecomrc-pzl-104]here[/link] ... am planning to put a fuel engine in it !
My Feedback: (13)
ORIGINAL: pettit
The PA-25 Pawnee looks suspiciously similar to the one from World Models, especially the color scheme and registration numbers.
I have one of them on the bench right now.
Wow, does share some similarities! Photo from WM, and other pic TBM specs... looks like the TBM plane is a bit smaller tho...
Correct, ours is a little bit smaller. Check out the price+shipping compared though: http://ecsvr.com/abm/shopexd.asp?id=3168 | http://www.troybuiltmodels.com/items...A25-97AAF.html
My Feedback: (10)
ORIGINAL: Tone Price
Hi everyone, I'd like to share a couple pictures of the ECOMRC CESSNA 195 107'' Wingspan right out of the box!
First impressions:
First impressions:
Rob(Australia)
Here's are a couple pics of the inside of the Cessna fuselage and also a couple of the ECOMRC Piper PA-25 97'' Wingspan!
Could you tell me that the FG57T engine fit under cowl without cutting them ? I would like avoid cut cowl. Could you send me dimension of cowl?
FL
Hi Derek, I just sent this reply to your email but thought I'd post it here so others can see as well:
I'm not sure if that engine would fit but can tell you the cowl dimensions are pretty big: http://www.troybuiltmodels.com/ns/in...ecomcowls.html This link shows the cowl dimensions for all ECOMRC planes so far. Measurements are taken from where most engines would be sitting and are conservative.
Judging be your the total width of the engine is 232 millimeters (9.13385827 inches) and our cowl measurement is 9". Here is a video of Gene showing different engine options in the cowl: http://youtu.be/_dJFJSag30U?t=2m59s he also makes mention that the diameter of the cowl is 11" so it's possible your engine would fit just fine before the cowl tapers down to 9".
Please give [email protected] an email if you'd like to know more!
Hi guys I have just about finished Putting together the ecomrc Pawnee and so far I'm pretty happy with model. I did make a
few changes though, such as fitting servos inside each stab half replacing the stock tailwheel with a Dubro unit adding tugging wires to the tail and changing the control horn setup completely for all surfaces. With a magnum 160 4-stroke twin fitted the model balances perfectly without lead! And had turned out looking neater than the original setup.
I have flown a mates ecomrc Wilga with an OS 33GT and has proven to be a great combo towing glider 3.5 meters easily!
I'm hoping to maiden my Pawnee shortly.
Tone Price what are the chances of ECOMRC doing some nicely sized motorgliders such as RF-4, Scheibe sf 28 ask 14 etc??
ORIGINAL: bignuts181
My Feedback: (23)
Tone I have the Texas RCPawnee, it looks similar to the ecom model this airplane is agreat flyer I have a DLE20 in mine, plenty of power. Its off the ground in 50 feet and I fly at half throttle. Your going to love this bird. Good luck with the maiden Ill be looking for your report.
VA
Hi there i am in the process of putting the pawnee together for my father as a gift i have a bme 44 not being used i know its more than enough but will be to much.
VA
Another ? I would like to have full scale lighting on the pawnee does anyone know of a kit that i could purchase thanks for the help
