Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Help identify this plane >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 10-24-2014 | 02:00 PM
My Feedback: (38)
Default Help identify this plane
Can anyone identify this plane?
It has a 6ft fuse, the span is 108.5in.
The chord is 16.5in
There is no sheeting in the wing or the fuse.
It is built using formers and stringers
The wings are pulled together using a turn buckle and wing struts.
If you have seen this plane let me know if it was a kit or a plans built or a scratch build please.
ID:	2041949   Click image for larger version
ID:	2041950   Click image for larger version
ID:	2041951   Click image for larger version
ID:	2041952   Click image for larger version
ID:	2041953   Click image for larger version
ID:	2041954   Click image for larger version
ID:	2041955   Click image for larger version
Old 11-04-2014 | 05:11 AM
scale only 4 me's Avatar
My Feedback: (158)
Interesting, based on the stringer construction, I'd guess someone enlarged a set of Gillows plans and scratch built it,,
Should be light,, have you tried to fly it yet?
Old 11-04-2014 | 05:28 AM
My Feedback: (38)
I got this from a friend of mine and he said he had flown it several times
It has a OS 120 in it
Old 11-04-2014 | 05:39 AM
My Feedback: (38)
it could be a cessna 172 also
Old 11-05-2014 | 04:02 AM
My Feedback: (158)
Yes, it's a Cessna, I thought you were looking for the designer or Kit Manufacturer
Too bad the N number is wrong (not accurate to the aircraft)
http://www.flugzeugbilder.de/show.php?id=528730
That might have given you the exact model
good luck
