Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Sig 1/4 Scale Clipped Wing Cub
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 02-03-2017, 12:10 PM
jimharley
jimharley's Avatar
More progress on the Cub. With any luck and a bit of good weather I should be able to run the engine this weekend. Building the struts turned out to be quite eye opening. I trust older designs, so I thought nothing about laying the struts out over the plan and drilling the necessary holes. When I mounted them to the wing the jury struts were way off. I contemplated leaving it alone because I didn't want to weaken the spruce struts with more holes. I compromised and made the front strut and then re-aligned the jury strut so the rear strut would be even with the front. It is now correctly drilled and mounted. I used JB Weld to fill the original hole, so hopefully this will add some strength to the area.
Jim
Started applying a few of the graphics
ID:	2199585   Click image for larger version
ID:	2199586   Click image for larger version
ID:	2199587   Click image for larger version
ID:	2199588   Click image for larger version
ID:	2199589   Click image for larger version
ID:	2199590   Click image for larger version
ID:	2199591   Click image for larger version
Old 02-04-2017, 06:50 AM
TomCrump
TomCrump's Avatar
Your Cub looks great, Jim !
My BUSA Cub is not nearly as far along in the build process.
Old 02-05-2017, 11:17 AM
jimharley
jimharley's Avatar
Thanks Tom! I'll be watching for updates on your Cub!
Jim
Old 02-19-2017, 12:09 AM
jimharley
jimharley's Avatar
She is airworthy...there was a beautiful weather window last weekend and my receiver battery stopped taking a charge. It's been raining ever since. I've been slowly adding details that I intended on adding after the maiden. There is a window tomorrow it seems, between 10 and 1...we will see how good the forecasters are New battery installed!
Jim
ID:	2201778   Click image for larger version
ID:	2201779   Click image for larger version
ID:	2201780   Click image for larger version
ID:	2201781   Click image for larger version
ID:	2201782   Click image for larger version
ID:	2201783   Click image for larger version
ID:	2201784   Click image for larger version
Old 02-19-2017, 05:07 AM
TomCrump
TomCrump's Avatar
Too bad about your battery problems.
I hope that your flying window is open today.
Good luck !
Old 02-19-2017, 07:45 AM
  #31
Joshsubmec
Joshsubmec's Avatar
Hey Jim,
Didn't notice you are in Redmond until now. I'm in the tri-cities area, woulda loved to see this bird fly. Good luck on the maiden!
Old 02-19-2017, 08:35 AM
  #32
spaceworm
Jim
She is beautiful You will love the way she flies. I have the FW Sig 1/4 Cub and the Hanger 9 100 inch fabric covered Cub. Good luck on your maiden.
Sincerely, Richard
AMA 861960
Cub Brotherhood #187; Sig 1/4 (Koverall/dope), H9 100 inch (Gen 1) (Solartex/?), GB Anniv Cub (NIB)
Sig Kougar, Sig 1/4 Cub, Sig 1/4 Spacewalker II
Kadet Brotherhood #96; Mk 1 Kadet, Kadet Junior,
Club Saito #635; Saito 56, 100, 120abc, 130T, 180
Old 02-22-2017, 11:52 AM
  #33
jimharley
jimharley's Avatar
Originally Posted by Joshsubmec
Hey Jim,
Thanks! she flew great! anytime you want to come fly over here let me know, just need an AMA card. Any Scale meets over your way? I've done a lot of flying out of Tri Cities airport.
Sincerely, Richard
AMA 861960
Thank you Richard! it is one of the oldest and best designed models out there that is still in production! I hear the Hangar 9 Cub is really nice flying machine as well.
Here are some pics from yesterday. I ended up taking the cowling off to make engine adjustments...it was a bit grouchy from not having run in a while. It is still not 100% but I got the high end smoothed out and the idle fairly reliable after about an hour of tinkering. I taxied it around for about 5 minutes to make sure the tailwheel springs were adjusted right. After a couple high speed runs with the tail up it felt right. I taxied back over to give the controls one final check and off she went. About half throttle it flew off with little effort. I did about 5 laps around the field and all it needed was a bit of down elevator trim and touch of left aileron. The engine hiccuped pretty good so I brought it in. Daylight was running out so hopefully the weather holds and I can get back out tomorrow early and get the engine dialed in. She still needs a bunch of the details added, seats, dummy engine, bungee covers...but overall its airworthy and I have a new favorite
I really appreciate everyone's kind words, advice and comments, been a blast getting back in to the hobby!
Jim
ID:	2202328   Click image for larger version
ID:	2202329   Click image for larger version
ID:	2202330   Click image for larger version
ID:	2202331   Click image for larger version
ID:	2202332   Click image for larger version
ID:	2202333   Click image for larger version
ID:	2202334   Click image for larger version
ID:	2202336   Click image for larger version
Old 03-19-2017, 11:42 PM
  #34
jimharley
jimharley's Avatar
My wife and I took the cub out flying today. She took a couple quick videos which I spliced together. Officially flights 4 and 5, the weather here has been crap. It is a great flying airplane, I can't wait for summer and better weather.
Jim
https://youtu.be/CgMnJRi8XR0
Old 03-20-2017, 03:18 AM
  #35
TomCrump
TomCrump's Avatar
She flies great, Jim !
Old 03-20-2017, 01:43 PM
  #36
CK1
My Feedback: (60)
CK1's Avatar
Jim , what an excellent build job. Your dad and grandfather would/should be very proud of the skills you learned from them . You learned well. I know I would be very proud if my son and grandsons could build like that .They can and do build some small projects but I just can't enough time with them to teach them much any more .
Old 03-22-2017, 09:45 AM
  #37
jimharley
jimharley's Avatar
Thank you guys! I've built a lot of models and I honestly don't remember any of them being this much fun! @CK, I am truly thankful they had the influence they had, this hobby continues to be a great journey.
Jim
Old 04-02-2017, 05:08 PM
  #38
spaceworm
Congrats Jim, sounds like your Sig J3 experience is same
as mine. I have been flying the full wing version for several years. Just today I scored a very well built and Koveral covered clipped wing at our club swap meet. It just needs painting.t
However, I do not have the struts for the CW. I think they are different than the FW struts. Do you have a copy of the CW strut detail you could send me. Any form is ok, a dimensioned sketch would even work for me. Thank you very much. Sincerely, Richard
Old 04-02-2017, 05:39 PM
  #39
jimharley
jimharley's Avatar
Yeah you bet...give me a day to get the plans out. Years ago I built the long wing...the struts are essentially the same, just shorter. The brass tubing is the same, the metal tabs are the same, and the spruce is the same. As far as I can tell they are very functional. I didn't fiberglass the center section but I did build a 20" box spar with carbon fiber tubing. So far so good It is a great flying airplane and is only getting better. You'll love yours!
Jim
Old 04-03-2017, 06:54 AM
  #40
spaceworm
Jim
Hi Jim, thank you very much for your kind and helpful offer. I have the FW struts, and since I expect to fly both wings on occasion. I will keep them intact. So, detail on the CW struts will enable me to make a set of them. No hurry, as we are just barely out of snow cover, and the field is soggy. Thanks again. Sincerely, Richard
