Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Missing washer for engine >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 01-31-2024 | 01:23 PM
Default Missing washer for engine
I have a OS 160 Gemini which I'm installing in a 1/4 scale cub. I removed the exhaust pipes and accidentally lost one of the copper washers that fit into the exhaust pipes inside the cylinder head. I found a washer of similar thickness and diameter but it is made of steel. I am concerned that if I use this in the exhaust it will corrode and get stuck ruining the engine. I tried the small washer from a glow plug but its a bit small. Don't know if its possible to order these things. Any ideas?
Old 04-07-2024 | 02:26 PM
Horizon hobby is showing this in stock. Might be your only option for original parts it is what you are looking for. Good luck
