Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Piper Tri-Pacer from Wendell Hostetler is now here!!
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 04-03-2016, 09:20 PM
  #251
P40N
P40N's Avatar
Finished panel, unlike any panel ever seen in a Tri Pacer!
I want to line the inside of the cabin but cant come up with a suitable material to look like the vinyl on the full size, have any of you guys got any ideas of what I could use?
Old 04-04-2016, 04:51 AM
  #252
TomCrump
TomCrump's Avatar
Your instrument panel looks great !
I buy my cockpit material at fabric stores, like Joann's. They may have something that you can use.
Old 04-09-2016, 04:04 PM
  #253
P40N
P40N's Avatar
I've just stuck on the tail feathers. Covering the fin and the back of the fuse is going to be fun....
ID:	2156561   Click image for larger version
ID:	2156562   Click image for larger version
Old 04-09-2016, 04:13 PM
  #254
avionics
avionics's Avatar
Magnificent job. Thanks for keeping us posted.
Old 04-13-2016, 02:03 PM
  #255
P40N
P40N's Avatar
And now the front end..
ID:	2157215   Click image for larger version
ID:	2157216   Click image for larger version
ID:	2157217   Click image for larger version
ID:	2157218   Click image for larger version
ID:	2157219   Click image for larger version
Old 04-13-2016, 03:22 PM
  #256
musterpilot
musterpilot's Avatar
Looking good Stan your a master builder keep up the good work
John
Old 04-13-2016, 05:20 PM
  #257
avionics
avionics's Avatar
Looks like a Gem. Beautiful .
Old 04-13-2016, 06:28 PM
  #258
geoardsog5
My Feedback: (31)
Very nice motor and cowl installation. How did you make out with the vert. fin covering? It took me 6 tries to get it right on the one that I did. i was afraid of running out of fabric. John R.
Old 04-13-2016, 06:47 PM
  #259
P40N
P40N's Avatar
Thanks for the encouragement guys.
I haven't done the fin / fuse covering yet, I'm still scratching my head on the way to go. John and John R did you cover the back of the plane and fin separately from the rest of the fuse or did you do the side and fin in one piece of covering. It's such an important feature that you guys have got right.
Cheers
Old 04-13-2016, 07:36 PM
  #260
geoardsog5
My Feedback: (31)
I put down a 1/4 wide strip of balsa sheet on top of the last fuse former and covered the top fuse - ending with a wrap there. Then covered the fin separately with a 1/4" overlap at that point. The fin was covered in left and right halfs. I can post pics, if this explanation, doesn't make sense. John R.
Old 04-13-2016, 08:36 PM
  #261
P40N
P40N's Avatar
Thanks John,
Pictures would sure help as I don't want to stuff this up.
Cheers
Stan
Old 04-28-2016, 10:30 PM
  #262
P40N
P40N's Avatar
The back of the Tri Pacer has a pretty unique blend of shape from the fin to the fuselage that I had been giving a bit of thought about how to replicate. The first two pictures are of the full size.
I took a tip from John R and gave up on the idea of covering fin and fuse in one piece and ended up creating a frame around the front of the tail and fillers around the elevator torque tube so I could attach multiple pieces of Solartex.
I covered the fin down to the first frame and then tried to span the gap between the fin and the outer fuse stringer. Two hours later and four pieces of wasted Solartex and it was done.
I found that the white painted Solartex was just too stiff to bridge the gap but raw unfilled Solartex stretched enough to do the job. Down side of using the raw cloth is that I'll have to paint it with a primer or I'll end up with two covering textures.
This is a fun build with plenty to do yet
Cheers
Name:	rudder to fues.jpg
ID:	2159885   Click image for larger version
ID:	2159886   Click image for larger version
ID:	2159887   Click image for larger version
ID:	2159888   Click image for larger version
ID:	2159889   Click image for larger version
ID:	2159890   Click image for larger version
ID:	2159891   Click image for larger version
Old 04-29-2016, 04:38 AM
  #263
TomCrump
TomCrump's Avatar
That area is a difficult one to cover. Natural Solartex makes the job a bit easier..
Old 05-05-2016, 09:56 PM
  #264
geoardsog5
My Feedback: (31)
Stan, You have got it. That's exactly what i did to cover the area. sorry, i couldn't find any good pictures to post. John R.
Old 05-14-2016, 11:35 PM
  #265
musterpilot
Well guys got the Pacer in the air today flew fantastic no bad habits said to the Mrs get out the camera but no she left it home didn't she well that's when the fight started
anyhow not to worry will try and get some photos up next week how is yours going Stan ?
John
Old 05-15-2016, 12:26 AM
  #266
P40N
P40N's Avatar
Congrats on the maiden John, well done, I'm still chugging along, just finished all the electrics, batteries, servos and now are making some cable trunks to hide the leads as they go into the wings also fiddling with the cabin lining and seats. I made some cardboard templates and covered them with heatshrink now I can fit door handles and trim wheel to the linings before I glue the linings to the cabin sides.
Hey John, what did you make your chairs from? I've tried foam but it looks a bit "howaryougoing", dont like seeing the open cells and filling them is pretty messy.
Cheers
Stan
ID:	2162480   Click image for larger version
ID:	2162481   Click image for larger version
ID:	2162482   Click image for larger version
Old 05-15-2016, 01:38 AM
  #267
musterpilot
Hi Stan thanks
I used BLUE foam for my chairs when you have cut and sanded it it won't look like foam when painted with water base house paint you can either use PVA or supa glue for your gluing
weight wise it is only a few ounces you can get the foam from any place that sells roofing and flooring insulation I got mine local in Perth so you wont have a problem getting it over there I think it only cost about $20 for a 1200x600 x25 sheet
John
Old 05-30-2016, 10:21 PM
  #268
P40N
P40N's Avatar
I had made up a panel for all the electronics and its time to connect up all the wiring so I needed to know where the batteries were going to live. I lashed up a balancing beam and surprise, surprise the plane is nose heavy with the big Saito and the substantial nose leg and wheel. The four LiPos wil reside as far down the back as physically possible.
Four LiPos under the stab
I fitted both wings so I was able to set up the cabin top root ribs and glued the wiring with a bit of Zap Goo to the inside of the ribs, I then made some extra ribs and fitted them 10mm inside the root ribs. The wing wiring was located between both ribs with an exception around the wing mounting spar. I would have liked to drill a hole in the spar to hide the wiring but thought that might be a bit unwise!!
All done with the first rough coat of Daytona White inside the cabin
ID:	2165181   Click image for larger version
ID:	2165182   Click image for larger version
ID:	2165183   Click image for larger version
ID:	2165184   Click image for larger version
Old 05-31-2016, 12:11 AM
  #269
musterpilot
Looking good Stan, my old full size Piper was red on the inside but I attacked it with a spray can of Piper grey looked much nicer after that
Keep up the good work mate
John
Old 06-04-2016, 06:54 PM
  #270
P40N
P40N's Avatar
Now that I've completed all the wiring and the internal painting I was able to glue the linings and instrument panel in place.
The door handles are a pretty crude make up from aluminium tube and plywood after my total failure to master CAD. I had hoped to draw scale handles and then print them out on a 3D printer, next life maybe.
Next step seats, seat belts and pilot.
ID:	2165807   Click image for larger version
ID:	2165808   Click image for larger version
ID:	2165809   Click image for larger version
Old 06-04-2016, 09:01 PM
  #271
musterpilot
Very nice Stan a lot better than mine keep up the good work
Old 06-13-2016, 11:22 PM
  #272
P40N
P40N's Avatar
Biggles has arrived, still not very happy. Time to make some seats and seat belts.
Thanks John for the XPS foam tip, I bought two 1200 x 600 x 30 sheets from Bunnings for $12
ID:	2167844   Click image for larger version
ID:	2167845   Click image for larger version
ID:	2167846   Click image for larger version
ID:	2167847   Click image for larger version
Old 06-13-2016, 11:35 PM
  #273
musterpilot
Where did you get the pilot Stan ?
John
Old 06-13-2016, 11:40 PM
  #274
P40N
P40N's Avatar
Gooday John,
I've had it for some years, one of those buys that might come in handy one day. I think I got it from Vailly Aviation. I bought a few pilots from them when I was doing my warbirds so they would be the most likely.
Cheers
Stan
Old 06-14-2016, 12:19 AM
  #275
musterpilot
Thanks mate will give them a try
John
