Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Hostetler 33% Decathlon
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 04-26-2011, 11:51 AM
  #3801
Big_Bird
Big_Bird's Avatar
Default RE: Hostetler 33% Decathlon
It does look a lot better. I see what you mean about the louvers. They need to be rotated as a unit clockwise maybe 10 or 15 degrees. Good job.
Old 04-27-2011, 04:54 AM
  #3802
Kellermann
Kellermann's Avatar
I think I will correct that later.
Here another bunch of pix to show the finished (almost ) fuselage, all it needs now is the clear cote.
ID:	1599882   Click image for larger version
ID:	1599883   Click image for larger version
ID:	1599884   Click image for larger version
Old 04-27-2011, 05:23 AM
  #3803
Big_Bird
Big_Bird's Avatar
It sure looks good!
Old 04-27-2011, 03:05 PM
  #3804
tflyrc
My Feedback: (9)
tflyrc's Avatar
I agree. The star did the trick. Looks great!
Tom
Old 04-27-2011, 04:26 PM
  #3805
Kellermann
Kellermann's Avatar
Hi Guys
first time standing on her own legs - donĀ“t mind the undersized wheels (5"), these are not the correct ones (6"), which are yet to arrive.
Also no TW yet. And the height of this beast added to the table height gives an optical illusion on the angle sheĀ“s sitting "on the ground". But everything is correct, believe me.
I didnĀ“t mount the wheelpants on because theyĀ“re still on their painting supports for clearcoating, after that I will of course take a photo session of the fully assembled model.
Enjoy.
ID:	1600081   Click image for larger version
ID:	1600082   Click image for larger version
ID:	1600083   Click image for larger version
Old 04-27-2011, 06:26 PM
  #3806
Kellermann
Kellermann's Avatar
Yet another bunch of pix - empennage all set up, a rock solid arrangement. I used 2-56 rods, threaded at one end, to allow for clevis adjustments (after done, a drop of cyano will give additional strength), and bent at the other end to prevent from slipping off. The clevis is the Du-Bro 2-56 Safety Lock Kwik-Link Cat. 816.
ID:	1600213   Click image for larger version
ID:	1600214   Click image for larger version
ID:	1600215   Click image for larger version
ID:	1600216   Click image for larger version
Old 04-28-2011, 01:15 AM
  #3807
Kellermann
Kellermann's Avatar
Guys, I am having trouble receiving notifiers, does anyone know what to do?
I now rechecked all boxes in my settings page, hope the notifier come...please post any comment so I can test it...thanks.
Marcus
Old 04-28-2011, 03:53 AM
  #3808
Big_Bird
Big_Bird's Avatar
The Super Deke looks great on the wheels.
Old 04-28-2011, 11:31 AM
  #3809
Kellermann
Kellermann's Avatar
Thanks Ken, I will pick up the FG parts from my autobody painter tomorrow, I never do the clearcoating myself, I want a pro doing it so it gets really right and fuelproof.
Got no notifier from your post...checking back at RCU a couple of times every day ...
Did the TW installation and glued in all hinges, did also the Rudder Pull-Pull installation. I dont like the size of the TW but itĀ“s what the owner choose.
For those who may ask, I always place a piece of cable inside the springs of the TW assembly to make it stiff (that eliminates the spring effect), otherwise there is no control especially in strong x-winds.
I will now proceed to the wing strut installation and adjustments and then I guess I am done.
Pix later.
Tomorrow starts our great annual fly-in FESBRAER (www.fesbraer.com.br), IĀ“ll share a few pix if I find something interesting...
Marcus
ID:	1600465   Click image for larger version
Old 04-28-2011, 11:44 AM
  #3810
Big_Bird
Big_Bird's Avatar
TW looks good. Marcus, go over to RC Universe Support / Forum questions or problems and ask about your problem with not getting notification. I'm sure you will get some help there.
Old 04-29-2011, 02:13 PM
  #3811
Kellermann
Kellermann's Avatar
Done!! Absolutely on schedule, I was able to finish the latest release, the brandnew 35% scale SD this afternoon...
CĀ“est finis! Je presente le derniĆØre Super Decathlon de MMF Ć* echelle 35% par moteurs 100-150cc ...
ID:	1600982   Click image for larger version
ID:	1600983   Click image for larger version
ID:	1600984   Click image for larger version
ID:	1600985   Click image for larger version
ID:	1600986   Click image for larger version
ID:	1600987   Click image for larger version
ID:	1600988   Click image for larger version
Old 04-29-2011, 02:14 PM
  #3812
Kellermann
Kellermann's Avatar
As soon as the owner gets the plane and installs everything, he promised me to send pix and vids...
Old 05-01-2011, 03:39 PM
  #3813
Big_Bird
Big_Bird's Avatar
Marcus, that is an outstanding airplane. The new owner will be really glad to get it. Looking forward to his flight photos.
Old 05-01-2011, 05:08 PM
  #3814
Kellermann
Kellermann's Avatar
it was a real eyecatcher at the Annual Fly-In this weekend, less than 10 minutes after assemblying the plane for the exhibition I had another order PREPAID in hands!!
If I had a demo plane flying around I am sure IĀ“d get more orders right away...
Of course I will post pix of the new SDs taking shape. Also of this one after itĀ“s completely done for flying at the final destination, some 2500 miles away from here.
Thanks for all kind words and support.
Marcus
Old 05-06-2011, 01:16 AM
  #3815
Kellermann
Kellermann's Avatar
Here are a few pix taken at our fly-in. I didnĀ“t register as a pilot, I only took the SD to the vendors area...I actually didnĀ“t see much of the show as I was "manning the booth" most of the time. So there are no further pix.
ID:	1604926   Click image for larger version
ID:	1604927   Click image for larger version
ID:	1604928   Click image for larger version
ID:	1604929   Click image for larger version
Old 05-09-2011, 09:33 AM
  #3816
Kellermann
Kellermann's Avatar
Here a couple of vid stills of # 022 built by fellow modeler Anderson Sprovieri, and a few links to his videos.
Maiden flight scheduled for next weekend. Vids and pix to come...
http://www.youtube.com/user/AnderSpr.../0/OBYyv0_xGhI
http://www.youtube.com/user/AnderSpr.../1/syLxZQ8m3K8
http://www.youtube.com/user/AnderSpr.../2/QGmc557ZFWI
ID:	1606150   Click image for larger version
Old 05-12-2011, 02:19 PM
  #3817
Kellermann
Kellermann's Avatar
A couple of pix of #026 coming off the mill...done in the ever present red white blue scheme. FG parts being painted.
This is a 30% scale SD.
ID:	1607675   Click image for larger version
ID:	1607676   Click image for larger version
ID:	1607677   Click image for larger version
ID:	1607678   Click image for larger version
ID:	1607679   Click image for larger version
Old 05-21-2011, 04:11 AM
  #3818
ludfleet
My Feedback: (10)
Hi Marcus, The 35% is an awsome job, just beautiful. What is the expected weight? The 30% is great as well ( as usual), Is the covering film or fabric on this one? Joe
Old 05-22-2011, 01:39 PM
  #3819
Kellermann
Kellermann's Avatar
Thanks Joe
I donĀ“t have the final weight, I am still awaiting photos and info from the present owner. As soon as I have it I will post here, of course.
Here are the final pix of the SD #026 boxed ready to ship.
#027 already in the works, and the second 35% will be started this week.
Meanwhile, I got sidetracked by another project which will take my evenings and eat up a lof of space in the workshop - I am cleaning the shop tomorrow and building a 4th table to receive that huge plane: an Airworld (Germany) Focke-Wulf FW-190 A8 with all bells and whistles, complete with a Moki 215cc radial engine and all out scale detailing. As this plane was bought in Austria and totally disassembled and the components spread over several persons luggage for weight and customs purposes, I am commissioned to reassemble the plane, re-install all the RC components and change the engine from a King 100 twin to the brandnew Moki. The plane itself was shipped in the "sarcophagus" depicted in the pic below...
As this is a totally off-topic here, I invite all who want to see the project going forward to check my HP at www.marcusmodelfactory.com/Fw-190.html. Leave your Google ChromeĀ“s Translator on to read everything in your own language.
Along with the pics of the latest SD there are 2 pix just to tease you guys a little...
Marcus
ID:	1612999   Click image for larger version
ID:	1613000   Click image for larger version
ID:	1613001   Click image for larger version
ID:	1613002   Click image for larger version
Old 05-25-2011, 08:37 AM
  #3820
Kellermann
Kellermann's Avatar
Guys, here are the first flight pix of the 35%...not in the best resolution, but that is what I got from the owner...
Enjoy
ID:	1614412   Click image for larger version
ID:	1614413   Click image for larger version
ID:	1614414   Click image for larger version
ID:	1614415   Click image for larger version
ID:	1614416   Click image for larger version
ID:	1614417   Click image for larger version
ID:	1614418   Click image for larger version
ID:	1614420   Click image for larger version
Old 05-25-2011, 09:02 AM
  #3821
Big_Bird
Big_Bird's Avatar
Those are good pictures Marcus. I'm sure he is really happy with it. You did a very good job with the plane. It looks like he is near a big city. What is it?
Old 05-25-2011, 09:35 AM
  #3822
Kellermann
Kellermann's Avatar
Thanks Ken, yes, heĀ“s more than happy. HeĀ“s still getting the feeling of the plane and of course, heĀ“ll do some customization regarding radio instalation, engine tweaking, smoke, etc...
If you like this one, wait for the next one, already in the works. Will be done in the livery below.
The city is called RECIFE, capital of Pernambuco State, some 3,000 miles from here...if you take a look at your Atlas, itĀ“s in the Northeast of the country, actually the most eastern edge of it - the point which is closest to Africa.
Marcus
Old 05-25-2011, 10:42 AM
  #3823
Kellermann
Kellermann's Avatar
Here is a bunch of flight line shots of Kit #022 pictured earlier on this page. Flight shots will be taken the next weekend at a local event. Will post after that. This one flies in Petropolis, 100km shy of Rio de Janeiro, Brasil.
Sorry to take over the page but it seems that things are a bit on the slow side at the guys...
ID:	1614445   Click image for larger version
ID:	1614446   Click image for larger version
ID:	1614447   Click image for larger version
ID:	1614448   Click image for larger version
Old 05-25-2011, 11:46 AM
  #3824
Big_Bird
Big_Bird's Avatar
Great looking plane.
Old 05-31-2011, 04:12 AM
  #3825
Kellermann
Kellermann's Avatar
Here are a few further flying shots of both aircraft mentioned before, the 30% and the 35%...
ID:	1617320   Click image for larger version
ID:	1617321   Click image for larger version
ID:	1617322   Click image for larger version
ID:	1617323   Click image for larger version
ID:	1617324   Click image for larger version
