Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Hostetler 33% Decathlon
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 12-13-2012, 07:16 PM
  #4001
Bobt2
Default RE: Hostetler 33% Decathlon
yes, excact fit part for part. than i hold the part on the top view of the fuse on the plan and it's too short!
Old 12-14-2012, 09:31 AM
  #4002
martinwpb
martinwpb's Avatar
Hi Guys,
Just signed up to the forum after seeing this thread. I'm about half way ready the whole thread but have a couple of questions that i haven't found the answer for yet.
I'm looking to buy the 30% scale kit from National Balsa. Where is a good place to get the Cowling/WheelPants/Canopy? And are these good fit for the 30%?
The main reason to go for the 30% versus 33% is that i can run it with a DLE-55 which keeps the cost down. Seems like for a 33% you need to run a DLE-111.
Regards,
Martin
Old 12-14-2012, 12:33 PM
  #4003
tflyrc
My Feedback: (9)
tflyrc's Avatar
If you go to the Hostettler web site he lists sources for all of these parts, except the canopy. Fibertech N More (The old Stans Fiberglass I believe) was orignally where I purchased my 30% cowl. It fitted well w/ my Hostettler plans (scratch built and several threads in this forum). Could also check Fiberglass Specialties.
Regards, Tom
Old 12-14-2012, 03:37 PM
  #4004
Bobt2
well, you don't need a 111. if you check on you tube, theres a nice flight on one with a zdz 80.
Old 12-14-2012, 06:32 PM
  #4005
ludfleet
My Feedback: (10)
The ZDZ 80 has the power of most 100's it should fly it just fine.
Old 12-15-2012, 04:35 AM
  #4006
Bobt2
i have a zdz super 80 that i would like to use, but at 9 1/2 " long it would be a pita to make it fit.major firewall mods to start.
Old 12-15-2012, 11:42 AM
  #4007
martinwpb
martinwpb's Avatar
Hi guys,
Thanks for some feedback. Hostetler says the weight for a 33% is 25-30lbs. If my memory is correct a DLE-55 produces around 30lbs thrust right? So should that not be adequate enough?
Martin
Old 12-15-2012, 12:27 PM
  #4008
tflyrc
My Feedback: (9)
tflyrc's Avatar
Martin: The 55 would be OK for the 30% but I agree that it would be pushing it for the 33%. You are not going to have unlimited verticle in either case.
Old 12-16-2012, 04:36 AM
  #4009
Bobt2
it,s not the weight only, it's a big airfame with lots of drag.i would think a 55 with a smaller prop would barely get it in the air
Old 12-16-2012, 05:59 AM
  #4010
Kellermann
Kellermann's Avatar
BobT which one are you building? if the 30%, a 55 would do fine, all my 30% SDs fly well with the 50-55cc.
If it is the 33%, I´d go for a 80 or 100cc. My 35% are a little larger than the WH 33% and were designed for the DLE-111 twin. Ken´s 33% flys with a ZDZ 80
Marcus
Old 12-16-2012, 07:18 AM
  #4011
John La Belle
My Feedback: (52)
Hi Bobt; I would suggust the DLE111 if you plan to use fabric covering- automobile paint- scale cockpit- scale screw ribstitching- landing lights etc. ( this will make the plane weigh about 37 lbs) the DLE111 will be plenty of power. the plane will not notice the extra weight if you are inclined to build in the extras. The DLE55 should be fine if built lighter but as others have said the best compromise might be the 80 size engines. I like to add scale items and am very happy with the DLE111 and my 37 lb. Decathelon cheers John
Old 12-16-2012, 07:41 AM
  #4012
martinwpb
martinwpb's Avatar
I wish there was a DLE in between the DLE-60 and DLE-111. Like the Zenoah GT-80 but the gt-80 only produces about 5.5hp which is the same as the DLE-55.
How does the DLE-111 fit in the 33% Hostetler?
Martin
Old 12-16-2012, 08:23 AM
  #4013
Bobt2
well, i,m lucky in that i fly imac style aircraft. i own several da's and have a 100 that would be perfect. not to be a snob, but no china engine for this old man
Old 12-16-2012, 09:36 AM
  #4014
Kellermann
Kellermann's Avatar
Well, nothing against the DLE engines but if you have a DA-100 that would be the perfect one for your SD. Carefully check if the spark plugs + caps will fit inside the cowl.
Marcus
Old 12-16-2012, 10:51 AM
  #4015
Bobt2
probally not, as well as the mufflers hanging out the bottom. or i could add canisters thru the fuse.
Old 12-16-2012, 10:59 AM
  #4016
martinwpb
martinwpb's Avatar
How does the DLE-111 fits in the 33%?
Old 12-16-2012, 11:39 AM
  #4017
John La Belle
My Feedback: (52)
The DLE 111 fits completly inside the cowl inc. plug wires with plenty room for landing light -batteries and light servo cheers John
  #4018
ludfleet
My Feedback: (10)
I have a DLE 100 in mine fits perfect.
Old 12-16-2012, 11:55 AM
  #4019
Kellermann
Kellermann's Avatar
Guess BOBT answered that.
I designed my 35% scale exactly for the specs of the DLE-111. The 2 exhaust stacks length can be trimmed to be flush with the cowl underline, as the exhaust tunnel rear of it is functional, that is, you cannot see the stacks in level (flight) mode however they protrude enough no to mess with the underside of the plane.
Did that with the PItts-Style Muffler on my 30% powered by a Fuji 50, too.
Marcus
ID:	1830826   Click image for larger version
ID:	1830827   Click image for larger version
Old 12-16-2012, 12:00 PM
  #4020
martinwpb
martinwpb's Avatar
Thanks John.. Yours looks real nice! I like to color scheme.
Hi Marcus,
Is your kit comparable to Hostetlers 33% price wise? (national balsa $425,- full kit)
Martin
Old 12-16-2012, 01:35 PM
  #4021
martinwpb
martinwpb's Avatar
John you have some more close up shots from your cockpit? It looks real nice!
Old 12-16-2012, 03:42 PM
  #4022
Kellermann
Kellermann's Avatar
ORIGINAL: martinwpb
Hi Marcus,
Martin
Martin, mine is more expensive. USD 1250 + 15% S&H. Check my website [link=http://www.marcusmodelfactory.com/Pre-os-e-Condies.html]Details[/link], to see why my SD is different from others... If your browser is Google Chrome, be sure to have your automatic translator turned on.
Cheers Marcus
Old 12-16-2012, 03:44 PM
  #4023
ludfleet
My Feedback: (10)
Hello Marcus, How did you do the exhaust on the 35% or the DLE111? Do you have any photo's that you would share? Joe
Old 12-16-2012, 04:10 PM
  #4024
Kellermann
Kellermann's Avatar
ORIGINAL: ludfleet
Joe the same as on the pitts style on the 30%. I didn´t yet build one for me, will have to check one of my customers. Will come back on this tomorrow.
Marcus
Old 12-16-2012, 04:28 PM
  #4025
Bobt2
ok, turns out the da 100 is actually smaller. fits in the cowl with a little room to spare, however i,m sure the front of the mufflers will poke out the front bottom.
