42% Super Decathlon Build
#259
My Feedback: (18)
RE: 42% Super Decathlon Build
Hello Ken and Tony; Giant scale are pleasant to build, but time consuming, here we are building a 1/3 scale J3 Cub, 42% J3 Cub, Giant Stick, Trainer50 to cover, after a low wing stick twin engine, Super Cub 1/3 scale and 42%, 100" P51 Mustang,25% scale Pa-18,1/4 scale waco; 35% Pt-17 , still 4 years to build and fly all those airplane.
#260
35% PT-17!!!!!!!!! that's 11.25 Ft wingspan!!!!! now I'm getting excited. Any ideas of the finished weight? I know I hijacked the thread. Back to the Decathlon.
#261
Here is a quickie update on the SD. The wood work is complete unless I think of something else. The yellow Monokote on the left side is to keep the wing from sticking to the fuselage when I put the fairing epoxy in to fill the joint between the wing and the fuselage. The epoxy is available from Aircraft Spruce and Specialty Co. I'll put Monokote on the right side next. The tail feathers have been covered.
Earlier I had a question about what covering material will be used. With the experience that Ross and I have had with polyester dress lining material we can not see any reason to go with anything else. We are using non-tautening Randolph's nitrate dope and Poly Tak to adhere the covering to the frame.
#267
My Feedback: (9)
NC
Ken: Re carving out the blue foam on your wing tips, you can simply poor a capful of epoxy thinner and it will dissolve the foam. You will be surpized how little it takes. Regards, Tom.
#269
Ken,
I have another question for you on covering material. Why do you prefer polyester dress lining material in comparison to Sig's Koverall? Is it due to available size?
#271
My Feedback: (14)
TX
ORIGINAL: RICKSTUBBZ
Ken,
Ken,
As far as performance I have used both side by side and find no quantifiable difference between the two.
What I do though is take a sample of koverall with me to compare weight and weave as there are different materials available under the heading of dress lining. The most important thing is to insure that you are purchasing polyester material not some other fiber.
Also the per yard price is lower than buying it as a hobby packaged material.
I am using Stitts Poly Tac for the adhesive costing $12.50 per pint. Sig Stixit will do the same job but I don,t know what the cost differential might be. You can also precoat the airframe stick down areas with nitrate dope and then brush thinned dope thru the fabric where you want it to stick down.
Happy New Year,
Ross
#273
Yesterday Ross came over and we put the epoxy putty (Quickfair) on the fuselage/wing joint. Last night I spent about an hour popping the two wings off. Even though I used wax on the Monokote as a mold release I still had to run a 0.007 feeler gage around the joint.
The putty worked great. Today I have been sanding the putty and applying Bondo spotting putty to a few places. I'll do the finish sanding tomorrow and then the wings will be ready to cover.
It's 83 degrees here right now and windy with clear sky.
Here are a few photos:
#274
Looking Great!!!
That pic of Ross kneeling beind the wing shows how big that thing is. Thats going to be one impressive plane.
Anthony
Anthony
#275
ORIGINAL: WacoNut
Looking Great!!!
Anthony
Looking Great!!!
Anthony
As you see it, all servos, batteries, and switches are installed and the plane weighs in at 36 pounds.
