Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
I need help finding parts for old waco
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 02-27-2009, 01:11 AM
carbunkle
Default I need help finding parts for old waco
I hope someone can help me find some stuff to get this old waco back in shape. It will be for display only, so I'd like to really slick it out.
I would like to get one of those old detailed looking wood props with the brass leading edges riveted on and a good looking spinner. I need a fake radial motor insert that I'd like to be a really scale detailed looking one. Also needs a spacer to move the prop frwd. And one last thing for now would be a detailed windsheid as the old one is shot. The plane has a 90in. span, not sure what scale that is, does anyone know? If anyone can help me I will really appreciate it.
ID:	1145847   Click image for larger version
Old 02-27-2009, 01:27 AM
Ram-bro
My Feedback: (101)
Default RE: I need help finding parts for old waco
checkout Frank Tiano's website, he sells the Radial engines. The plane is approximately 1/4 scale/ You might be able to find a solo prop out there that you can trick out. Good luck
Old 02-27-2009, 01:55 AM
carbunkle
rgr tht. thnx rb
Old 02-27-2009, 06:59 AM
TomCrump
TomCrump's Avatar
For a great looking dummy radial, check out Williams Brothers. They have much more detail than any of their competitors.
Tru Turn should be able to set you up with the correct spinner.
Clark Airscrew has great laminated props. You'll have to add the brass detailing and find the correct prop logo.
My guess is that you'll have to fabricate your own windsreen, but proctor sells a 1/4 ay beable to purchase one from them.
Old 02-27-2009, 07:44 AM
Stickbuilder
Stickbuilder's Avatar
You can make the scale dummy engine as I did. Look in the Vintage and antique section. The spinner needs to be something like the AT-6 spinner. You will need to make your prop from something like the Zinger prop, and detail it to scale. This model appears to be a 25% version, since the span for a correct quarter scale is 90 inches. It could be one that was built from a Jim Pepino plan. The windscreen needs to be built up from wood and lexan. Hint, save a couple of 3 liter soft drink bottles.
Bill, Waco Brother #1
Old 02-27-2009, 09:11 AM
khodges
You can make your own detailed prop. Use a 26" Zinger, and cut an inch off each end (squared). Use aluminum HVAC tape and drawout the shape for the brass L.E., make a pattern and trace it to the tape, cut out and apply. A piece of wooden broomstick makes a good spacer, mount it to the firewall and extend it through the center of the dummy engine. Drill a hole centered in the stick, and screw the prop to it. You can also make a scale prop hub using a fender washer of the appropriate diameter and some #2 hex-head screws to simulate the nuts holding the prop on.
ID:	1146023   Click image for larger version
ID:	1146024   Click image for larger version
ID:	1146025   Click image for larger version
ID:	1146026   Click image for larger version
Old 02-27-2009, 10:30 AM
Stickbuilder
Here's what you can do yourself for a dummy engine.
ID:	1146066   Click image for larger version
Old 02-27-2009, 11:49 AM
Chad Veich
My Feedback: (60)
Looks like a Pica Waco to me. If it is then it's either 1/5 or 1/6 scale, they offered both. Just FYI, this particular version of the Waco did not have a spinner originally, although some restored examples do have them added.
Old 02-27-2009, 12:53 PM
Stickbuilder
ORIGINAL: Chad Veich
Chad,
Nope. It's not a Pica. He reported the wingspan to be at 90". That makes it a quarter scale. I'm betting it's from a Pepino Plan.
Old 02-27-2009, 01:16 PM
carbunkle
thnx guys. great info
Old 02-27-2009, 01:23 PM
carbunkle
Mr. Hodges, Can you and anyone else post some more pics of your Wacos?
Old 02-27-2009, 03:17 PM
Chad Veich
My Feedback: (60)
ORIGINAL: Stickbuilder
Chad,
You're right Bill, I managed to overlook that info in the original post despite reading it several times. My bad! Thanks for the correction.
Old 02-27-2009, 03:29 PM
Stickbuilder
ORIGINAL: carbunkle
Go to the Vintage and Antique forum. In there you will find a, "Little Thread", on the Waco YMF. You should find everything you ever wanted to know about all things Waco.
Old 02-28-2009, 03:21 PM
carbunkle
rgr tht , thnx- unbelievable, that thread has to be a record.
Old 02-28-2009, 05:52 PM
carbunkle
Well I thru some stuff together today for the prop and here is what I ended up with. Should do for display. Now to get a dummy radial. Think I may have to go with the cheapo vacuformed one.
