RCU Forums
-   Giant Scale Aircraft - General (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/)
-   -   Material Availability (https://www.rcuniverse.com/forum/giant-scale-aircraft-general-467/8796478-material-availability.html)
Skratchbilt 05-25-2009 08:08 AM
DEAD STICK!!!!!! Ha, got ya.
Does anyone have any ideas about where one could acquire balsa dimensionals (1/2x1/2 - 3/4x3/4 - etc.) with lengths up to eight feet? Having committed myself to a 30% build, with determination to replicate all facets of detail (aside from metal tubing), I have found myself stuck by the inavailability of lengths of balsa. I flinch at the thought of splices, laminations and/or other means of acheiving length. Anything?
ByLoudDesign 05-25-2009 08:44 AM
RE: Material Availability
I have never seen anything longer then 48" in all my searches. You might concider spruce stringerOf a equal strength!</p>
http://www.aircraftspruce.com/catalo...s/capstrip.php</p>
</p>
</p>
Skratchbilt 05-25-2009 09:28 AM
Thanks BLD,
Aircraftspruce is a well used site, that didn't get much thought in this matter.I guess 'cause of "half-timer's" desease. lol.
SoCalSal 05-26-2009 11:48 AM
Give SiG a call..if what you want is even out ther in that length they will know for sure. You see Sig owns their own balasa tree farms. If 8 foot balsa is even out there they would be the ones to contact.
Skratchbilt 05-26-2009 04:09 PM
Thanks SoCalSal,</p>
Aircraftspruce has the lengths in spruce, but I will try SIG.Thanks. I'll let ya know.</p>
Skratchbilt</p>
Skratchbilt 05-26-2009 06:44 PM
After careful consideration, this bird will be built using sruce! I can't get dimensional balsa as long as I need it, so spruce it is. Going over the rough dimensions, the longerons will get as long as 6'9", and the spars for either wing will be 48". I think spruce will be fitting for the detail I seek. Once this build gets rolling, the shots will be posted! Be patient though.</p>
</p>
Thanks ya'all</p>
