1/2A to electric conversion
This is a scaled down kaos called a Kaotic by ptulmer. 30.5" wing span with an e-flite park 400 turning a 10x7 APC E with a 25A CC ESC and TP 3s 1320 mAh lipo. 3 hs-55's. Moves out in a fairly serious fashion.
http://www.rcuniverse.com/forum/m_55...mpage_2/tm.htm
There are some other guys building glow powered verions which will be just as cool. Check out ptulmer's site:
http://www.ulmer-rc.com/dotnetnuke/default.aspx
NC
that thing probably hauls ASS!
I wonder what it would do on 4s with a smaller prop?
And smaller wings?
and servos mounted inside the fuse?
and a smooth cowling?
and wing bolts?
Looks like you have yourself quite a bit of work to do before your beating the nitro guys.
But good job!
And smaller wings?
and wing bolts?
But good job!
