Tweety Bird Conversion Completed
1 Attachment(s)
Well I don't know how it will fly but here are the specs.
The tweety bird is a 48" wingspan version of the Diry Birdy.As you can see some kit bashing took place. This one was made from a vintage kit that i purchased off from ebay. Weight: 4.5lbs fully loaded Motor: Rimfire 35-36-1200kv Prop: 9x7.5 Battery: 2x 4s - 2650ah in parallel Power: draw 500-525 watts The ESC is located in the custom made conopy with cooling holes. Two servos in the wing, two in the tail. All servos are Hitec HS-65HB When will I make a maiden flight? I don't know, have to get a decent charger and complete a few details. What do you think? will it fly? |
RE: Tweety Bird Conversion Completed
That is one GOOD lookin' sleek plane. It looks fast just sitting. Good luck on maiden. Check and recheck the COG.
gb |
| All times are GMT -8. The time now is 11:59 PM. |
