Help Engine Trouble!
Heres the problem....about 2 months ago my engine mounts came loose and I stripped the spur and cluth gears 2 times... Now that i have replaced them my engine will run and the crankshaft will spin but the car will not go...........PLEASE HELP
Run it and give it a few good blips on the throttle. If the clutch gets hot it is a drive train problem. If it stays cold, the problem is the clutch.
