Help, ENGINE PROBLEMS!
Old 08-02-2003 | 10:52 PM
Default Help, ENGINE PROBLEMS!
Hello,
I have an HPI RS4 2, and I just put a nitro star .15fe in it, it was running great and then I shut it off to take a break, and i went back to start it and it started up and the engine just started running full throttle and went wild, i checked to see if the throttle was on idle and everything looks fine, whats the problem? Help!
some people say i have carborator problems, but i dont know what to do.
Old 08-02-2003 | 11:59 PM
Check to make sure the throttle is actually working. Then,,, if it is, take it back to where you purchased it. good luck.
ZB
Old 08-04-2003 | 12:40 AM
Flyboy Dave's Avatar
My Feedback: (21)
Default odear09....
....there's a little set screw that holds the throttle arm
to the carb barrel....see if it hasn't come loose on you.
Dave.
